Old 06-12-2014, 04:52 PM   #1
FrankWest
FrankWest's Avatar
Default manually spinning engine
without a starting crank can an engine be gentily rotated by moving the fan belt??? Not started by just to see if the motor is not seized??
FrankWest is offline   Reply With Quote
Old 06-12-2014, 05:00 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: manually spinning engine
Not necessarily ALWAYS. I have been able to "rotate" SOME engines by the belt, while others would not rotate so easily, depending on how "un-stuck" the particular engine is, and on how tightly the belt grips the crank pulley. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-12-2014, 05:04 PM   #3
Joe K
Joe K's Avatar
A lot of this may depend on how worn your engine is.
New engines with new compression tend to be harder to turn and start with a crank.
Older engines - like the original engine to my truck, could be turned with a crank held in two curled fingers (no thumb!) and would certainly start - but had no particular power and one of those "extended" crankcase breather thingies - and an accessory trail of blue vapor.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 06-12-2014, 08:01 PM   #4
Paul
Paul's Avatar
Pull the plugs and turn away.
it's all good
Paul is offline   Reply With Quote
Old 06-12-2014, 08:26 PM   #5
Fred K-OR
Fred K-OR's Avatar
Originally Posted by rustyrim View Post
use a socket on the crankshaft. You can bend the fan.
A number of the vendors offer a wrench that is like a socket ,to be used for this purpose.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 06-12-2014, 10:10 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I heated and bent my own special box wrench for the front crankshaft bolt. This is handy to get the bolt loose.
It really is a special bolt, so why is it called a nut?
