Old 06-09-2014, 10:14 AM   #1
41merc
Default Sealing filler neck at gas tank
Please tell me the best product to use to seal the filler neck at the gas tank on my 37 pickup. Just started leaking.
Thank you
41merc is offline   Reply With Quote
Old 06-09-2014, 11:13 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Sealing filler neck at gas tank
A liberal coating of non-hardening Permatex always did the trick for me.
Old 06-09-2014, 11:19 AM   #3
AnthonyG
AnthonyG's Avatar
I believe you have the threaded collar connecting the tank to the filler neck? If so there is a large lead washer which goes on the threaded collar and on tightening the collar it seals with the lead crushing / sealing. Lead Washer only good for one application, If tank is removed after a new lead washer is required.
Nomad
AnthonyG is offline   Reply With Quote
Old 06-09-2014, 12:22 PM   #4
34PKUP
34PKUP's Avatar
If it does have a crush washer, a coat of Permatex won't hurt.
34PKUP is offline   Reply With Quote
Old 06-09-2014, 12:48 PM   #5
G.M.
I coat the washer with gas tank liner material. G.M.
www.fordcollector.com
