Old 06-07-2014, 07:31 PM   #1
Jay Ess
Jay Ess's Avatar
Default Spring Modifications for my 30 Speedster
I am finally ready to re-spring my Speedster. I will be using a T rear, and a Posies A reverse eye and lower arc spring which is said to lower the front end by 2". I understand that the T spring should accomplish the same drop in the rear.
I am also interested in making the ride as compliant as possible. I am trying to figure out how I can at least be in the ballpark with initial modifications as I would like to eliminate as much trial and error as possible and hopefully minimize the number of times I will need to repeat the assembly/test/dis-assembly process.
The drive train is 100% stock with regard to its weight. It began its life bodied as a 4 door sedan. It is now aluminum bodied and the skin weighs about 50lbs (on the high side). There is a steel 1x1 sub-frame to which the body is attached and in total the materials weigh about 40lbs. The wood floorboards are still in place, and the fuel tank is the same weight as stock.
What I am trying to calculate is the difference in sprung weight between a 4 door sedan (body/interior) and my car as it stands now. I have searched the site, but I have been unable to find the weight of a 4 door sedan body, fenders, bumpers, etc..
Any help with that measurement would be appreciated!
Once that weight is a given, I will try to guesstimate a benchmark ratio of the stock spring rate, to the stock sprung weight. Once a baseline is established I will start removing leaves in an attempt to match the ratio.
I am hoping that the local spring shop will be able to help me with the measurements of my initial, and modified spring packs, using their shop equipment. I would hope that this get me in the right zone before I begin testing on the car.
Am I on the right track? Any input, insight, criticism, or comments are welcome.
Thanks,
js
Old School Aficionado...
H.A.M.B. Alliance Member
Jay Ess is offline   Reply With Quote
Old 06-07-2014, 09:43 PM   #2
Brentwood Bob
Default Re: Spring Modifications for my 30 Speedster
2462-2475 lbs on the 4door sedan. Roadster was 2155 lbs.
Brentwood Bob is offline   Reply With Quote
Old 06-07-2014, 11:10 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
You may also want to post this in the HAMB site to get the question before the greatest number of people with experience on non stock A's.
Old 06-08-2014, 09:37 AM   #4
gz
gz's Avatar
This roadster has an 8 leaf T rear spring and a reversed eye 7 leaf front spring. Being a roadster, it should be much heavier than the speedster you described. It rides fine and does not bounce, sway or bottom out. It has standard Model A shocks although I am not sure what condition they are in or if they are really even absorbing any shock. I have driven the car thousands of miles, most on the road but also on some very twisting and turning road race courses.
I had a 1928 tudor with the same spring configuration. The extra weight of the tudor body caused the car to sway left and right as well as bottom out when on rough roads-which we have a lot of in Detroit. Tube shocks and a panard bar helped to remedy this.
gz is offline   Reply With Quote
Old 06-08-2014, 01:39 PM   #5
Jay Ess
Jay Ess's Avatar
Bob, thanks for the response. Would you know the weight of just the body, fenders and bumpers as this would be sprung weight. Thanks, js
Thanks Mike. I am a member and will be posting over there as well. I thought that this would be the best place to ask about the weight of just the body. I also know that a number of members have dabbled with speedsters over the years and have shared their knowledge in the past.
js
Thanks for the seat of the pants guidance! js
Old 06-08-2014, 03:04 PM   #6
gz
gz's Avatar
Keep in mind you are doing what thousands of other people have done since the day the first Model A became a used car. No real reason for calculations or analysis!!!! Just do it and get on the road!!!!
Old 06-08-2014, 03:15 PM   #7
Jay Ess
Jay Ess's Avatar
Red face Re: Spring Modifications for my 30 Speedster
Boy I wish I could! I have this personality disorder that will not allow me to consider having fun unless I anguish over every detail. It sucks...
Old 06-08-2014, 11:58 PM   #8
Brentwood Bob
no clue on chassis weight. IMHO 1500-1700 lbs. I have lifted alot of the parts separately.
Old 06-09-2014, 03:48 PM   #9
Big John
discuss some issuses with parts suppliers... they should know what sheet metal weighs they have to ship it to you....
Big John is offline   Reply With Quote
Old 06-09-2014, 05:03 PM   #10
john in illinois
john in illinois's Avatar
For the front spring,you might want to contact posies direct when you have your weight . I put a posies front spring on my Tudor and they sent a different number spring than I ordered . I called and they said that number would work better. Car sits and rides good. Nice folks to deal with.
John
john in illinois is offline   Reply With Quote
