Old 06-04-2014, 08:03 AM   #1
bluesman31
bluesman31's Avatar
Default 36 Ford Pickup steel bed?
I am looking at a 36 ford and it has and all steel bed. Basically a steel sheet built over plywood base. Looks clean. I am trying to determine if this is considered correct? I always assumed that they all had the oak boards and metals strips. I am assuming this is simply the way it was restored and not original or correct? in any way?
31 Deluxe Roadster
bluesman31 is offline   Reply With Quote
Old 06-04-2014, 08:10 AM   #2
Scott H
Scott H's Avatar
Default Re: 36 Ford Pickup steel bed?
The bed frame has hardwood planks on the underside and a solid steel bed floor on top. The bed steel is embossed with rub strips that look similar to the strips you would normally see on the wood beds.
36 1/2 ton pickup
on 38 car frame
with 1940 v8 24 stud
Scott H is offline   Reply With Quote
Old 06-04-2014, 09:14 AM   #3
bluesman31
bluesman31's Avatar
This one looks like this
31 Deluxe Roadster
Old 06-04-2014, 12:08 PM   #4
Lawson Cox
Lawson Cox's Avatar
35-36 Ford pickup beds have a wooden sub floor covered with a steel sheet that has ribs or rub ridges that are embossed in the sheet. The one you are looking at and pictured is not correct. No plywood sub floor and no smooth bed floor cover.
Mac Hils makes the correct bed. Mac's bed as produced is not exactly correct for show. Call me at 404-316-6748 and I will be glad to talk to you about it.
I have one on my pickup and am very pleased with it. Lawson Cox
Old 06-04-2014, 01:09 PM   #5
bluesman31
bluesman31's Avatar
Thanks
31 Deluxe Roadster
Old 06-04-2014, 02:57 PM   #6
36Bill
36Bill's Avatar
There is a picture of my '36 stock pickup bed in the album on my page. Click on my name and then the album.
Bill
The best way to have a friend is to be a friend. Howdy Doody
36Bill is offline   Reply With Quote
Old 06-04-2014, 03:25 PM   #7
Mike B
Hey Bill, what's the plate for in the rear of the bed?
Mike B is offline   Reply With Quote
Old 06-04-2014, 03:53 PM   #8
Lawson Cox
Lawson Cox's Avatar
Cover for gas tank sending unit inspection hole.
Old 06-04-2014, 04:07 PM   #9
V12Bill
V12Bill's Avatar
All Ford pickups had the steel bed floor with the wood planks undeneith for strength from 1928 to 1950. I like the looks of a nicely stained wood bed, but it is not correct.
V12Bill is offline   Reply With Quote
Old 06-04-2014, 04:16 PM   #10
Mike B
Thanks
