Go Back   The Ford Barn > The Archives > Early V8
Old 03-30-2005, 02:25 PM   #1
Guest
Posts: n/a
Default 39 hydraulic brakes on a 38
I am trying to convert my 38 Ford to juice brakes. I am told that it is easiest if I use pedals from a 39. I have the bracket and pedals. Can this be installed without cutting the frame or making other modifications? Does every thing line up the same? Thanks.
Old 03-30-2005, 02:43 PM   #2
Guest
Posts: n/a
Default Re: 39 hydraulic brakes on a 38
I don't know about a '38 but on my '36 which I intend to mount a '39 pedal assembly I will have to make a couple of minor changes to the frame. Some one out there will know about what needs to be done on your car.
