#1 |
Guest
Posts: n/a
I might be the only guy on this forum that doesn't know but I doubt it.Would someone explain step by step the procedure for claying heads? Or suggest a book? Do you torque down head bolts or studs? Where do you buy clay,like an art supply store? Is the desired clearance on valves .50 and pistons .100? Do you measure the clay with a micrometer after compressing it? So many questions. Will someone have pity on the this ignorant soul? |
#2 |
Guest
Posts: n/a
You aren't the only one who needs an explanation on this question. |
#3 |
Guest
Posts: n/a
You don't need to torque the heads to spec, just to about 45 ft. lbs. Modeling clay is what most people use. Get it from an arts and crafts store. Be sure to smear some motor oil or grease on the pistons and valve heads to keep the clay from sticking to them. Rotate the engine through a couple of complete revolutions by hand to compress the clay, then remove the head and measure the thickness witha a machinist's ruler. Check the pistons in several different areas, the domes and and around the edges. .050" to .100" over the pistons is good, but performance suffers a bit with piston to head clearnce over .050". Valve clearance shoud be at least .040" with a a gasket thickness of .55", a bit more is better for flow. You can reuse the gaskets. |
