Old 05-20-2014, 10:31 AM   #1
Tod
Default New block update 3.
I just finished boring the cylinders in the first sample block. They came out very well. Not a mark in them. I cut them .005 under so they can be honed to size. That pretty much does it for the top end.
Later today I plan to set the block up in an HMC and begin machining on the sides and ends. After this, I will be able to test fit most, if not all, external bolt-on parts. I happen to be running flywheel housings and heads for Snyder right now so that will give me fresh parts in house to bolt on.
That will leave the cam and crank journals and the main oil galley.
I will be sending pics out to people who have requested them.
Tod
Tod is offline   Reply With Quote
Old 05-20-2014, 10:43 AM   #2
Franchise_24
Franchise_24's Avatar
Default Re: New block update 3.
Thanks for the update Tod. Very exciting!
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 05-20-2014, 10:49 AM   #3
mshmodela
mshmodela's Avatar
Great work Tod! I for one thank you for doing that which is needed --esp. since so few today have the skills to even try what you're doing.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 05-20-2014, 11:21 AM   #4
Tod
Don't be impressed. It really isn't very difficult.
Tod
Old 05-20-2014, 04:58 PM   #5
George Miller
George Miller's Avatar
Tod
It would be if you never have done it.
George Miller is offline   Reply With Quote
Old 05-20-2014, 05:07 PM   #6
mshmodela
mshmodela's Avatar
Originally Posted by tod View Post
don't be impressed. It really isn't very difficult.
Tod
bs!
-Mike
Cleveland, Ohio
Old 05-20-2014, 05:16 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Tod
Nothing is difficult if you know how. The know how is difficult.
Old 05-20-2014, 07:56 PM   #8
bikejunk
thank you its amazing I cant get a garbage can lid to fit properly let alone cast and machine a piece of history !
bikejunk is offline   Reply With Quote
Old 05-21-2014, 10:58 AM   #9
Jim Brierley
tod, no need to allow .005 to be honed. i only leave .0005 - .001, thus requiring less honing, which is hard work if doing manually. goog luck on the rest of the project!
Jim Brierley is offline   Reply With Quote
Old 05-21-2014, 11:19 AM   #10
Tod
Thanks for the input Jim. On this first one I wanted to make sure it could be take out to stock size even if it needs a light boring first.
This morning, in between running production and running some errands I cut the water outlet on the side. I will be spending today and this evening getting the sides and ends cut.
Tod
Old 05-21-2014, 05:30 PM   #11
Tod
Today, in between production, and at the end of the day, I was able to finish up the side water-outlet face and bolt on a borrowed water-neck. Looks good. Then I faced the valve cover side and drilled/tapped all those holes. I need to get some bolts to fasten everything on but I did put studs in and fasten on an intake and one of my cast iron tube headers. Everything looks good on that side also. So far, so good.
Sorry it is taking so long but my primary use of machines is production. It is time consuming to put something in without fixturing and plow through it. It will get there. Please be patient.
Tod
Old 05-21-2014, 06:53 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
"Sorry it is taking so long but my primary use of machines is production. It is time consuming to put something in without fixturing and plow through it. It will get there. Please be patient."
Not a problem.
We've only been waiting 85 years for a new engine. LOL
Glad to hear it going well so far.
Old 05-21-2014, 08:47 PM   #13
tbirdtbird
We will continue to be patient; you are on our side! A very worthwhile endeavor indeed; keep up the good work.
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-21-2014, 09:31 PM   #14
Gold Digger
It sounds like good news Tod. I've been following along with this for a long time and can't remember what kind of crank you plan to use in this new block. Is it pressure feed or original type. Somebody bring me up to speed.
Gold Digger is offline   Reply With Quote
Old 05-21-2014, 10:45 PM   #15
Dusty
Dusty's Avatar
Tod
Yea, I'm cranking these things by the dozen in my little garage
P.S. what I would really like is a diesel engine that looks like a Ford Flat head four that is about 200 HP gets 45 mpg and still sounds like a Model A
Still dreaming in WV soon to be head south
dusty
Dusty is offline   Reply With Quote
Old 05-22-2014, 05:22 AM   #16
Tod
Pressure feed is the plan.
Tod
Old 05-22-2014, 07:02 AM   #17
Mitch//pa
thats great Tod
three successful updates so far in the same month of the same year...
wow the impossible now seems obtainable
thanks for the update are you able to post pics at times??
Old 05-22-2014, 07:56 AM   #18
Tod
Originally Posted by Mitch//pa View Post
thats great Tod
Mitch, I will be sending out some pics today. I am running to Fastenal to buy some bolts to bolt on the valve cover and side cover. I started to cut the rear end of the block but ran out of time this morning. Production comes first.
I did cut the front cover surface to length but didn't have time to drill and tap the cover bolt holes. I measured the length against a stock block and it looks good.
Tod
Old 05-22-2014, 09:19 AM   #19
Crazydaddyo
Crazydaddyo's Avatar
Pictures....YAAAAAAAAAY!!!!!!
I can't wait!!!!!!!
Crazydaddyo is offline   Reply With Quote
Old 05-22-2014, 09:55 AM   #20
Bill in SoCal
Bill in SoCal's Avatar
Tod
Tod, I would like to see the pictures. I think a lot of others would too. Bill
Bill in SoCal is offline   Reply With Quote
