Old 05-04-2014, 07:57 PM   #1
gpits68
gpits68's Avatar
Default best thing to clean running board rubber with ?
Hello all , hope everyone is enjoying the spring weather and getting their A's road ready . Does anyone know the best way to clean the rubber on the running boards . Mine do not look the best and appears to have whiteish spots where things have been set on them . I hope they will clean up .
Gary P.
gpits68 is offline   Reply With Quote
Old 05-04-2014, 09:09 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: best thing to clean running board rubber with ?
maybe some of the tire cleaners that are out there, test on the tire to make sure it doesnt make it slipery.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-04-2014, 09:35 PM   #3
Clem Clement
Clem Clement's Avatar
tried kerosene? use on a small spot to be sure it doesn't curl the rubber.
Clem Clement is offline   Reply With Quote
Old 05-04-2014, 10:20 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
I don't know if it is the best or not but I use tire cleaner.
Old 05-04-2014, 10:28 PM   #5
Jim Huseby
Jim Huseby's Avatar
Magauir's makes a spray rubber and vinyl cleaner that I scrub the r'bd with using a vegetable brush, then dry with towelling. It comes out really black and clean.
Jim Huseby is offline   Reply With Quote
Old 05-04-2014, 10:30 PM   #6
mass A man
mass A man's Avatar
Hot soapy water, a stiff brush & elbow grease. Always worked for me.
mass A man is offline   Reply With Quote
Old 05-04-2014, 10:46 PM   #7
MBI Houston
MBI Houston's Avatar
I use Surf City Beyond Black on my running boards. It is easy to apply, dries fast, is not sticky and is not shinny but yet it looks good.
MBI Houston is offline   Reply With Quote
Old 05-05-2014, 04:58 AM   #8
Dusty
Dusty's Avatar
I used a black spay paint for vinyl, my rubber had a worn sun bleached look to them. Tire stuff would helped for a day or so and fade. The rubber now looks new and is holding up well and would be easy to redo.
dusty
Dusty is offline   Reply With Quote
Old 05-05-2014, 05:57 AM   #9
Mike
Mike's Avatar
To CLEAN the rubber I use simple green, hot water and a stiff brush.
Mike
Mike is offline   Reply With Quote
Old 05-05-2014, 06:09 AM   #10
SeaSlugs
SeaSlugs's Avatar
Originally Posted by Clem Clement View Post
tried kerosene? use on a small spot to be sure it doesn't curb the rubber.
i would not try kerosine, ive been using it as parts washing fluid and any rubber grip tool and my shoes just soak it up like crazy and never seems to dry out so it reeks like kerosine for days. even when you think its gone if it starts to get hot you can start smelling it again.
Old 05-05-2014, 06:18 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
WD-40 cleans the rubber grips on tools very well.
Old 05-05-2014, 06:33 AM   #12
C26Pinelake
I have also used WD 40 on the running boards. The first coat I let sit for a day.. I then stiff brush it and wash it off with very warm sudsy water. After dry time I then respray and wipe with soft cloth. I have been asked many times how I get them so nice..
Wayne
C26Pinelake is offline   Reply With Quote
Old 05-05-2014, 10:10 AM   #13
FL&WVMIKE
FL&WVMIKE's Avatar
It sounds crazy, but the BEST thing that I have ever found for cleaning black tires and running boards is BLACK STOVE POLISH !
It really dyes the rubber a black, black and lasts forever.
The rear tires on this replica racer were white walls, until one treatment of black stove polish.
MIKE (mikeburch)
CLICK ON PHOTO TO ENLARGE - Twice
FL&WVMIKE is offline   Reply With Quote
Old 05-05-2014, 01:36 PM   #14
bobpo1
bobpo1's Avatar
MIKE (mikeburch)
Mike, where'd you get the black stove polish?
bobpo1 is offline   Reply With Quote
Old 05-05-2014, 02:41 PM   #15
Russell in Tulsa
Jim Huseby, don't look now but in your avitar it looks like the stuff totally ate your running boards off!
Russell in Tulsa is offline   Reply With Quote
Old 05-05-2014, 04:54 PM   #16
d.
source for black stove polish:
try Tractor Supply, Ace Hardware, a wood stove store, or any farm supply store, lots of folks still use this for their woodstoves.
d. is offline   Reply With Quote
