Go Back   The Ford Barn > The Archives > Early V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Re: 1946 Ford Backup Light Switch Mounting
I can send (E Mail) you some Photos of one tomorrow if you want me to.
Old 03-23-2005, 01:59 PM   #2
Guest
Posts: n/a
Default 1946 Ford Backup Light Switch Mounting
Need some help please. Where and how is the backup light switch mounted? Does anyone have any mounting instructions they could e-mail me?
Thanks!
Steve
Old 03-23-2005, 02:12 PM   #3
Guest
Posts: n/a
Steve, The switch is mounted to the steering column just in front of the firewall. It is arranged in such a way as to be activated when you shift into reverse. the shift linkage presses against the plunger on the switch.
Old 03-24-2005, 02:52 AM   #4
Guest
Posts: n/a
You can also mount a pressure switch somewhere in your brake line - might be easier but not as original. 40s had it that way...
