#1 |
Guest
Posts: n/a
I have noticed some 33 Ford pickups use a stainless grille trim. Does the stainless trim off a 32 commercial work or what year would fit. Thanks for your help |
#2 |
Guest
Posts: n/a
They might just have installed a 34 truck grille that has the stainless and the holes for clips. Other wise I believe the grilles are the same. |
#3 |
Guest
Posts: n/a
The top part of the shell is different between 33 and 34. |
#4 |
Guest
Posts: n/a
Showing my ignorance again, but wasn't the 34 the only one that used a grill stainless trim? |
#5 |
Guest
Posts: n/a
Between the 32, 33 and 34's that is. |
#6 |
Guest
Posts: n/a
Yes I believe you are correct my friend has a 33 and he was wondering if the stainless came off 32 or 34. We are going to get a 34 stainless and hopefully put it on his 33. |
#7 |
Guest
Posts: n/a
I think you can do that but you will have to drill holes for the clips. Maybe you could install it using some of this double stick tape they put moldings on with nowadays. |
