Go Back   The Ford Barn > The Archives > Early V8
Old 03-23-2005, 12:59 PM   #1
Guest
Posts: n/a
Default Re: "A" heads on 59AB block
None, you will actually gain torqie. The "A" heads have less volume and the 59 series engine has more cubes. The small amt removed for valve clearance shouldn't be a factor.
Old 03-23-2005, 01:02 PM   #2
Guest
Posts: n/a
I have a set on an 8ba milled .040" measured CR is 7.2
Old 03-24-2005, 03:05 AM   #3
Guest
Posts: n/a
Hummmmmmmmmmmm. I just put stock Mer heads on my 8BA (also Merc crank/pistons) I know I gained cubic inches but what did I gain or lose using Merc heads Vs. the 8ba?
Thanks in advance.
Dave
Old 03-24-2005, 03:05 AM   #4
Guest
Posts: n/a
Thanks in advance.
Dave
Old 03-24-2005, 03:05 AM   #5
Guest
Posts: n/a
Thanks in advance.
Dave
