#1 |
Can someone post a picture of the internal parts of Ford (Unity) foglights? Specifically the bulb retainer, if there are such pieces? Thanks in advance.
I dig coal, which provides motivation for EVs. |
#2 |
Are you referring to the bulb-and-socket type? If so, I don't have one near right now, but they took a bulb with a flange similar to the early headlights.
#3 |
I believe so. Was there little spring clips to hold the bulbs? Have a picture of such lights as a reference.
http://www.bing.com/images/search?q=...lectedIndex=18
#4 |
1952henry, Polosi better convince their EPA of that since they won't allow natural gas to be used to power natural gas pumps , must use electricity in new applications. No problem though, Obama just won't let the new transfer pipelines lines to be built.
#5 |
Those look like sealed beam lights. Yes, there are spring clips to hold the bulb in the retainer ring. I think NAPA sells them. If I remember correctly, there are four clips per bulb.
#6 |
#7 |
They are part number 6598 in the upper left of the attached
http://www.unityusa.com/assets/image...PartsSheet.pdf |
#8 |
Thanks all. So 'tis just the little spring clips that locate the bulb assembly. I really appreciate that.
Keith, maybe the pumps can be plugged into a "currant" bush.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 04-28-2014 at 04:28 AM. |
