Old 04-15-2014, 09:39 AM   #1
36tbird
Default stainless trim clips '36 grille
I am putting the stainless on a '36 grille not previously drilled for the trim. I think that rather than use the original spring type clips, I would like to secure the trim with those universal trim clips that have the 10-32 stud and rectangular flat metal top that can be trimmed down to fit inside the s/s trim. I can find batches of them on the 'bay, but wondering if anyone in Fordbarn world has a good source for them. Or, other suggestions for securing the trim to the grille would be appreciated. Thanks.
36tbird is offline   Reply With Quote
Old 04-15-2014, 09:53 AM   #2
41PICUP
41PICUP's Avatar
Default Re: stainless trim clips '36 grille
Try looking at part number 40-8200-HK from Bob Drake.
1934 grill trim hardware kit.
I used them on my 36 for both the grill trim and the spare tire trim.
Worked well.
41PICUP is offline   Reply With Quote
Old 04-15-2014, 12:27 PM   #3
36tbird
Thanks, 41. After looking at them, could it be that they are just small carriage bolts?
Old 04-15-2014, 02:29 PM   #4
deuce lover
deuce lover's Avatar
The problem with those nut plates is in certain areas you can't get a wrench or socket on the nut.I used the repo clips and they worked out fine.I got my clips from The Early Ford Store in CA
deuce lover is offline   Reply With Quote
Old 04-15-2014, 02:50 PM   #5
36tbird
Just did a search of 10-32 carriage bolt dimensions. The square shoulder is .185 to .199 and measuring the inside slot of the s/s it looks like about .200. I think 41 may have given me a great idea to use the carriage bolts.
D.L., that's why we have drills to put holes where Henry should have.
Old 04-15-2014, 05:16 PM   #6
mrtexas
mrtexas's Avatar
Macs sells little square headed bolts for fasteners. I used them. You must have the grill off to put the trim on and they are difficult to use but work. I had to make my own fasterners for the center grill piece. The Macs wire fasteners are junk, way to stiff and a bigger guage wire than the originals.
https://fordbarn.com/forum/showthread...light=36+grill
mrtexas is offline   Reply With Quote
