Old 04-08-2014, 12:04 PM   #1
Zaemo
Default 1932 Ford ON/OFF Switch Lever
City: Decatur
State: GA
Price: $55.00
This is a reproduction ignition lever switch in the correct nickel finish. This lever is cast in heavy silicon bronze material and then nickel plated by myself. It is exactly like an original lever including the indentation on the inside for the small spring that rides between it and the shaft. You may or may not have to file the inside slightly depending on the amount of wear on your shaft. It fits every internal shaft I have tried it on without any filing whatsoever. It is a very nice fit. It also features the slot in the rear, as original, to accommodate the rear plate tab.
The last picture shows the lever in a column drop along with a preliminary version of the ON/OFF switch plate (escutcheon) that will be available hopefully by this summer (or sooner)! I will be listing it here also when it becomes available.
If you are not happy with it, please return it unmodified for a full refund minus shipping costs.
$55.00 includes shipping via USPS to the 48 States.
Thanks! PM me or email me at [email protected]
WANTED:
1932 Front X-Member
1932 Rumble Seat Back Spring Cushion- Roadster
32-34 Roadster Windshield Cones
Original 32 Straight Rear Spreader Bar
Zaemo is offline   Reply With Quote
Old 04-15-2014, 01:11 PM   #2
Zaemo
Default Re: 1932 Ford ON/OFF Switch Lever
back up
WANTED:
1932 Front X-Member
