Old 03-31-2014, 09:57 AM   #1
Mongo
Default Starter/generator end play
Tried to find info on starter and gen end play.
Any suggestions out there would be greatly appreciated. Thx again.
Mongo is offline   Reply With Quote
Old 03-31-2014, 10:08 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Starter/generator end play
The generator really shouldn't have any end play that you can feel.
The starter might have about .005" to .015" or so end play that you can feel. You can correct the end play with a new thrust washer on the commutator end.
Old 04-01-2014, 09:10 AM   #3
Mongo
Again Thx a bunch for the info.
Old 04-01-2014, 10:17 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
Bratton offers a fiber thrust washer that goes at the front of the shaft next to the commutator Page 70 part # 15790 price $1.85 . Snyders offers a rear thrust washer in two thickness .030 & .060 . These parts are on page A-149. These type washer-shims can be used on starters or generators. Rear thrust is most important on starters and don't make all that much difference on a generator. I have used them on both to take up end play. use steel on the starter rear thrust and fiber at the commutator end.
