Old 03-28-2014, 08:29 PM   #1
Richard/Tennessee
Richard/Tennessee's Avatar
Default 16" Ford wheels
What tires r u using on the 16" rims????
Richard/Tennessee is offline   Reply With Quote
Old 03-28-2014, 11:06 PM   #2
quickchange
quickchange's Avatar
Default Re: 16" Ford wheels
205 -80 8ply radials, No body roll due too soft side walls.
quickchange is offline   Reply With Quote
Old 03-29-2014, 12:05 AM   #3
waxhead
waxhead's Avatar
Firestone Black wall Bias ply 650-16
waxhead is offline   Reply With Quote
Old 03-29-2014, 04:26 AM   #4
chopo
rear 750 16 front 550 16 firestones
www.jalopyshowdown.com
dont scare me i poop easy
chopo is offline   Reply With Quote
Old 03-29-2014, 10:46 AM   #5
glenn in camino
glenn in camino's Avatar
They will make your Model A look funny
glenn in camino is offline   Reply With Quote
Old 03-29-2014, 11:58 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
On this one I run 700x16 mud grips on the back and 600x16 on the front. The 700s are close to the outside diameter of the original 19s and doesn't slow top speed like a smaller diameter 16 inch tire WILL. On the front, 5.50s would steer better but this is what was given to me so, I decided to use them on my farm truck.
Old 03-29-2014, 12:39 PM   #7
bettlesr
bettlesr's Avatar
Dunlop Grandtrek 215/70R16 radials. I run them as tubeless. This size was originally used on the RAV4.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 03-29-2014, 03:27 PM   #8
Duffy1
ditto post #7 size; cooper tires, tubeless
Duffy1 is offline   Reply With Quote
Old 03-30-2014, 09:57 AM   #9
A-Jay
A-Jay's Avatar
if someone was going to order stock of the rack 16" black steel rim to fit a 1930 Model
A what would the bolt pattern measurements be and off-set if that apply's. What size tires are guys running to get close to stock diam. Also can we run a low cost radial or should we use bias plys ?
Where there's confusion, there's money!
A-Jay is offline   Reply With Quote
Old 03-30-2014, 12:09 PM   #10
1931 flamingo
1931 flamingo's Avatar
Ford wheels from the 40's (and Merc) fit, 5x 5 1/2 is the bolt pattern I believe. Some later Ford p/up wheels also fit. Your choice either bias or radial, most run tubeless.
600x16, 650x16, radials a lot of fellows run P215-70R16's.
Paul in CT
