Old 03-25-2014, 09:45 PM   #1
ifightfire
ifightfire's Avatar
Default 1930 coupe floor pan replacing weld or rivit?
Is there any reason i cant weld in my new replacement floor panels?
ifightfire is offline   Reply With Quote
Old 03-25-2014, 10:46 PM   #2
Drive Shaft Dave
Default Re: 1930 coupe floor pan replacing weld or rivit?
You could weld in the floor panels ,but the best way is to rivet them in.
Drive Shaft Dave is offline   Reply With Quote
Old 03-26-2014, 07:36 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Welding does not allow for any movement and greatly increases the chance of cracks.
Old 03-26-2014, 07:50 AM   #4
wrndln
I agree with Dave and Mike. Ford welded a lot of stuff together, but they rivited the frame together and many other items on the body. They must have had a good reason (flexing and movement as Mike indicated) as welding would have probably been easier, but they riveted many panels when they were installed.
Rusty Nelson
Old 03-26-2014, 09:14 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
Welding will stiffen the floor area locally, so when the car flexes, that welded floor panel will absorb more load than it if it were riveted. This could lead to some buckling of the welded panel. Stick with rivets or screws, and use some waterproof caulking as anti-squeak material.
Bob Bidonde
Old 03-26-2014, 10:13 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
I used screws on mine. It was quick and easy. Mine aren't for national judging but for enjoyment. If need be I can easily remove and replace the floor panels.
Old 03-26-2014, 12:26 PM   #7
ifightfire
ifightfire's Avatar
Im thankful I asked. im thinking I will screw them in. thank you
