#1 |
Our club attended the Northern Ca Spring Opener in Ukiah recently. On the way home, one member lost a blade from his original fan. It wiped out a nearly new Brassworks radiator and put two dents in the upper right hood panel.
This fan had been wet-Magnafluxed at an aviation repair shop and certified free of cracks, yet failed within about 1400 miles of installation. Guys and gals, take those original welded blades off unless you're about to enter judging. Which reminds me, IMO it is WAY past time for the standards to allow reproduction fan blades. Joe P.S. According to the adjuster, his Grundy insurance will cover all the damage except for the broken fan blade itself.
1929 Tudor since 1962 Feather River A's |
#2 |
What if I were to tell you that someone is seeking feedback on possible manufacturing of a NEW reproduction stamped steel 2 blade fan. How many here would step-up and buy a brand new 2-blade fan that would be look authentic enough to pass as NOS?
Feedback?? . |
#3 |
Several years ago, I drove my 31 Vicky to church, on way home no problem, stopped to let son get paper out of paper box, he said there was water coming out of hood loovers, drove 300 more feet to park at house, opened hood and the two blade fan had ate the radiator, got me, cost a lot to fix and never was the same fit with different radiator, get them out before someone is killed by a bad blade, Bruce
As far as look alike, I don't care, let us see one, Bruce |
#4 |
I think the clearly all original blades should be removed and become part of your tool kit for the judges to inspect. Use a repro for goodness sake. This is a known safety issue which should stand higher the demand for originalness.
clem Clement |
#5 |
[QUOTE=JoeWay;5985]Our club attended the Northern Ca Spring Opener in Ukiah recently. On the way home, one member lost a blade from his original fan. It wiped out a nearly new Brassworks radiator and put two dents in the upper right hood panel.
Guys and gals, take those original welded blades off unless you're about to enter judging. Which reminds me, IMO it is WAY past time for the standards to allow reproduction fan blades. Very good safety point. Mark
A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
#6 | |
I'd guess a lot of people including me would be in at $75 or so. Not so many at $100 or more. Joe
#7 |
Yup some people never learn and insist they still have the same air that Henry put in the tires. As far as Brent's hint I for one would want to know where the steel came from to manufacture new ones.
#8 |
I would be interested
#9 |
Me too..!
#10 |
I would within reason.
#11 | |
, ...but this person is a well known manufacturer of quality Model A parts that we all know. Guessing "out-loud", I would expect the finished product to probably be about double that Joe, maybe even triple that. For me personally, I would probably buy 10-12 of them a year just because they would be an accurate reproduction that works correctly and looks authentic. I realize many probably won't see the value over the alum. 2 blade but on the flip side, it is truly amazing how many folks out there pay extra for Goodyear tires instead of the cheaper ones, --or pay extra for the Bill Stipe shocks or his new camshafts, or purchase the new electronic distributers and Aries mufflers and such that is of higher quality and more authentic looking. One thing is for sure, I suspect that if there are new authentic-looking two-blade fans available, I doubt you will ever see the Stds. change. ![]() . |
#12 | |
#13 |
I would be interested in one for one car, but I also would be interested in a better made aluminum fan for other cars.
#14 |
Me too! I would buy one also because the body work repairs would be alot more. $75.00 to $100.00 would then be cheap
#15 |
A guy that i know has been working on this idea of a Authentic STEEL 2 -blade fan for a year now.. What is holding him up in the AUTHENTIC WELD SPOTS .Everything else there is no problem. I just spoke to John and he plans making a trip to Ford Headquarters and see is there is some kind of blueprints. Brent send me a email or call and maybe your guy and my guy can hookup and share ideas and $$$$. We need only 1 person to do this in this kind of market.
#16 | |
![]() What has me curious is what is AUTHENTIC WELD SPOTS? Using the analogy as above, Aries mufflers are not "exact" due to manufacturing costs but they are "close enough". Stipe's shocks are not "exact" because he made some slight internal modifications to improve on design and/or reduce production times. They are "close enough" to get the job done. My point is that IMO, sometimes we need to be careful while swallowing the camel that we don't choke on a gnat. Otherwise these ideas kinda stagnate just sitting on the drawing board.. |
#17 |
I have seen a fan off a Model A and one off of a Model T (both owned by the same guy) come through the hood. If you have a safe option that is nearly original I'd say God bless ya - send me a bill
Peace & Grace, Eric Swanson 1931 Model A Pickup |
#18 | |
I agree that such a fan would cause the standards to remain status quo. Joe
#19 |
Brent , the weld spots around the hub/fan blade to hub. Having a hard time doing the same spot welds.Other then that all is good to go.
#20 |
[QUOTE=JoeWay;5985] Which reminds me, IMO it is WAY past time for the standards to allow reproduction fan blades.
The standards do allow a 'original style metal fan' to pass prelim judging. Then it's a points deduction in final judging. They have for over a year...fwiw,jm |
