Old 02-18-2014, 12:15 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default After market upper steering column bushing (Brussegard?)
I've got one of Brussegard's upper steering bushings that fits in the column tube, got many years ago. There are two small set screws at the top of the bushing that I can't get to; does anybody know how this works. Would imagine the set screws are suppose to lock on to the steering shaft but I don't see how to make that happen.
36tudordeluxe is offline   Reply With Quote
Old 02-18-2014, 12:35 PM   #2
Steve Staysko
Steve Staysko's Avatar
Default Re: After market upper steering column bushing (Brussegard?)
I just ground down the correct size allen wrench so that it fit in the tight space.
Steve Staysko is offline   Reply With Quote
Old 02-18-2014, 02:12 PM   #3
36tudordeluxe
Thanks Steve, don't know why I didn't think of that.
Old 02-18-2014, 04:31 PM   #4
jerry grayson
The ones I have used come with a short allen wrench.
jerry grayson is offline   Reply With Quote
Old 02-18-2014, 05:14 PM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
The Brusegard (sp?) upper steering column bearing is the Cadillac of these upper column bearings being offered, but for those not willing to spend that many $$'s there are other lower cost ball bearings that also work well. One is still offered by FoMoCo but I don't have that part number handy. The other option, that I am aware of, is a flanged ball bearing with the correct ID & OD. It is actually a wheelbarrow wheel bearing available at TSC for about $3.00 to $4.00. I will edit this post later with that part number.
These previous posts listed below have pictures and part numbers of these bearings.
http://www.fordbarn.com/forum/showth...column+bearing
http://www.fordbarn.com/forum/showthread.php?t=61577
John
Old 06-01-2014, 06:45 PM   #6
Fordestes
thanks a bunch , It looks like I need a little practice on the search feature, I pulled up a few threads but none were the same as you all sent to me .
Thanks again!
Fordestes,
Fordestes is offline   Reply With Quote
Old 06-01-2014, 07:24 PM   #7
oldbugger
oldbugger's Avatar
I would be against using wheelbarrow bearings, we go through them in a short time at work. Some bearing companies make a better grade bearing with the same specs as tsc. omho
oldbugger is offline   Reply With Quote
Old 06-01-2014, 10:48 PM   #8
JSeery
JSeery's Avatar
Remember, a wheelbarrow bearing carries a lot more load that an upper steering column bearing!! The original was a bushing, and the later ford bearings were nothing to right home about in the strength department. Even tilt Chevy column bearing wouldn't last two minutes in a wheelbarrow environment.
Old 06-02-2014, 01:43 PM   #9
FlatheadTed
FlatheadTed's Avatar
I use the rubber bush from macs and drop a modern bearing on top of it .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-04-2014, 05:56 PM   #10
Royal Ryser
JM 35 Sedan has the answer. Use a "wheelbarrow" bearing and you will be plenty satisfied.
This is one place where we all seem to want to over-do a fix to a simple problem. If a $4 bearing will work, why use a $15 one?
Royal Ryser is offline   Reply With Quote
