Old 01-24-2014, 01:09 PM   #1
Afordman31
Afordman31's Avatar
Default Distributor Mounting screw and locking nut
Anyone have an idea for a wrench modified for loosening the nut that locks the distributor in place? This is a real pain to loosen using the after market exhaust manifold. After the nut is loosened it is easy by using a screw driver to unscrew the locking screw. Any help or pictures of a modified wrench would be appreciated. Afordman31
Afordman31 is offline   Reply With Quote
Old 01-24-2014, 01:34 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Distributor Mounting screw and locking nut
Maybe a picture would help since I'm not sure what kind of manifold you have. But, most folks have a few wrenches that have been 'warped' to suit their needs.
I've not seen an instance where a straight 9'16" didn't work.
Old 01-24-2014, 01:55 PM   #3
jw hash
jw hash's Avatar
take a 3/8 fine threaded bolt and cut it the same length as the screw turn the end down and just use a 9/16 wrench on it. be careful not to over tighten the bolt.
jw hash is offline   Reply With Quote
Old 01-24-2014, 01:59 PM   #4
CarlG
CarlG's Avatar
A 90 degree screwdriver works
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-24-2014, 02:47 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
I did about the same thing on a used HC head. I bought the head at a swap meet and didn't notice that the threads were stripped in the head. I had to go with the next larger size bolt and retap the head
Old 01-24-2014, 07:40 PM   #6
redmodelt
redmodelt's Avatar
Just don't over tighten the bolt. One of our customers did that and crushed the casing enough to put a squeeze on the shaft. Screw or bolt, just tight enough to hold, not to crush.
Old 08-01-2024, 03:00 PM   #7
FrankWest
FrankWest's Avatar
This bolt is a real pain in the ass.
I removed it easily enough to switch out distributers and now I CAN'T get it back in?
FrankWest is offline   Reply With Quote
Old 08-01-2024, 03:59 PM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Geez Frank, you dug really deep to bring this one out!!
I tend to have the best luck installing the Distributor Set-screw first sans the Lock Nut. Twist the set-screw backwards while pushing against the threads to make sure you are straight, and then begin turning the screw inward. On the off-chance your cylinder head threads are bad, try using a thread chaser or bottoming tap in the hole to clear the threads.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-01-2024, 05:03 PM   #9
Ernie Vitucci
Ernie Vitucci's Avatar
I agree with Brent....Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 08-01-2024, 07:39 PM   #10
Gene F
Gene F's Avatar
My setscrew has gotten stiff. Now days if I wanna pull the distributor I slip my 9/16 in there and back my lock nut off about 1 turn. Since the setscrew turns with it then I simply pull the distributor up.
Everyone is correct, they need not be very tight.
Gene F is offline   Reply With Quote
Old 08-02-2024, 10:42 AM   #11
nkaminar
nkaminar's Avatar
Would a set screw with an Allen wrench end work here? My manifold is stock and not in the way so I just use a regular screw driver, but I know some of the manifolds used for heaters get in the way. I guess the other option would be to drill a hole through the manifold to allow a regular screw driver to work, assuming the hole would not go into the exhaust passage. If it did, maybe a pipe plug would work. As far as modifying a wrench is concerned, most wrenches are hardened and hard to bend, so a torch is needed to bend them. Without a photograph, it is hard to recommend how to modify a wrench. I would say just to modify it to fit.
Old 08-02-2024, 10:51 AM   #12
Dale'45
Our '30 coupe has an Autolite heater manifold . No problem with a 9/16s combination wrench and a screwdriver through the hole in the manifold. Dale
Dale'45 is offline   Reply With Quote
