Old 01-16-2014, 02:22 PM   #1
Uncle Bob
Uncle Bob's Avatar
Default Johnson adjustable lifters
City: MV
State: Wa
Price: $75
This is an old, used set of Johnson hollow adjustable lifters for flathead Ford V8 engines. One lifter is an oddball, but the same size and function as the other 15. As with any used lifter these should be refaced by a qualified cam grinder such as Delta cams to be compatible with a different camshaft. The faces are in good shape otherwise. $75 + the ride. Sold
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
