Old 01-05-2014, 12:38 PM   #1
Richardtx
Default closed drive universal install
When you bolt the universal joint to the output shaft on a closed drive transmission is there play on the shaft. I have about a 1/4" play with the bolt tightened.
Thamks
Richardtx is offline   Reply With Quote
Old 01-05-2014, 12:57 PM   #2
ken ct
Default Re: closed drive universal install
If your referring to the single center bolt to the trans output shaft NO should be no play front to rear. Are you sure its tight or maybe you have the wrong U-joint in there. ??? ken ct.
ken ct is offline   Reply With Quote
Old 01-05-2014, 01:48 PM   #3
Richardtx
Thanks Ken, it is a 32' transmission. The universal joint is a Bob Drake reproduction. Are there different universal joints for different applications?
Old 01-05-2014, 02:08 PM   #4
john in illinois
john in illinois's Avatar
I think u-joints are the same 28-48. Ther is a special thick indexing washer under the bolt. You have to get the tang in a slot.
You might check that it is installed right.
John
john in illinois is offline   Reply With Quote
Old 01-05-2014, 03:25 PM   #5
Brendan
Brendan's Avatar
Chinaville u joint? maybe they lost something in the conversion from English to metric
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 01-05-2014, 04:40 PM   #6
ken ct
If you don't have that super thick washer under the bolt you would have about 1/4 " of in + out play.There is no index that I know of??? ken ct.
Old 01-05-2014, 05:17 PM   #7
rich b
rich b's Avatar
Do you have the right length bolt, so it gets tight before bottoming out? The original bolt is pretty short.
Maybe feel in there and see if it just the joint moving the 1/4" or if the output shaft is moving also.
rich b is offline   Reply With Quote
Old 01-05-2014, 05:21 PM   #8
hardtimes
hardtimes's Avatar
Thamks
Hey Richard,
There should be a 'special' THICK washer that is ALSO has a slight curved shape to it that fills that space that you are talking about...did you install that , eh NO play / looseness should exist and make bolt tight !!
hardtimes is offline   Reply With Quote
Old 01-05-2014, 07:59 PM   #9
Richardtx
Yes, there is the thick washer that is dished and the attaching bolt is short. I'm pretty sure the thick washer is tightly bolted to the end of the transmission output shaft and there is still play on the universal joint.
Old 01-06-2014, 08:19 AM   #10
Juergen
I would suggest taking the U-joint off and tightening the bolt with washer to ensure that the bolt is tight to the end of the output shaft. The U-joint is used to pull the rear bearing tight against the output shaft to hold the back end in place. It must not be loose or the output shaft can move back and forth and you won't be able to stay in gear.
Juergen is offline   Reply With Quote
Old 01-06-2014, 08:43 AM   #11
ken ct
Sounds lke you got a big problem there,hope not. ken ct.
Old 01-06-2014, 09:43 AM   #12
jimvette59
jimvette59's Avatar
Just had a after thought.
May be the snap ring is not in place on the front bearing, therefor the bearing is pushed back in the transmission. I think ????
jimvette59 is offline   Reply With Quote
Old 01-06-2014, 10:00 AM   #13
David J
David J's Avatar
Did you happen to forget snap ring [ B-7020 ] as the problem you describe is what leaving it out does . It goes on the rear bearing and holds it in place in the case . Post 12 was on the right track - just the wrong end of the tranny .
David J is offline   Reply With Quote
Old 01-09-2014, 03:46 PM   #14
DICK SPADARO
I'm bring up this post again as I just got off the phone with a customer that had a similar issue with the Drake universal joint.
After questioning him like Perry Mason I still could not determine what the issue was so I got a new U joint and a transmission out of stock and proceeded to install the joint.
Well the customer was correct and the U joint did not operate correctly or bolt down correctly. To determine the issue I disassembled the U-joint and determined that the heavy main drive washer supplied in the U -joint was installed incorrectly. My customer felt that that was the issue so I went with his suggested problem.
By flipping the washer over so the cup or concave side faced the main shaft and reassembled, the U joint functioned and installed correctly. Thus I think that this is the issue with your U joint. Look in the spline drive shaft end if the washer is concave to your sight its inverted as to its correct position. To fix the issue you must disassemble the u-joint and flip the washer so the concave faces the transmission mainshaft and everything will work as intended.
Don't go posting about "whaaa waaa Chinese parts or import stuff" its a QC issue and hard to spot. BD has been notified of the issue so I'm just passing on the info.
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 01-09-2014, 05:36 PM   #15
Richardtx
Thank you for your input. I will do what you explained. I can see the thick washer and the concave is reversed.
