Old 11-17-2013, 08:01 PM   #1
freak
freak's Avatar
Default steering wheel orientation
The thread on the light switch orientation made me remember to ask. Is there a correct orientation for the steering wheel? x or t? Mine is neither, it's kind of in between. Also how do you change it?
freak is offline   Reply With Quote
Old 11-17-2013, 08:09 PM   #2
whirnot
whirnot's Avatar
Default Re: steering wheel orientation
Mine is "T"
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 11-17-2013, 08:12 PM   #3
Smurkey
Smurkey's Avatar
Well, "kind of in between" is my vote...That's what mine is.
Steve
Smurkey is offline   Reply With Quote
Old 11-17-2013, 08:16 PM   #4
Joe K
Joe K's Avatar
Preferred was X and Ford gave instructions in the Service Bulletins for the keyed steering wheel which has two positions. If found in "T" (which can happen through wear or adjustment or damage) the wheel can be repositioned by removing and turning 30 degrees and putting on the "other" keyway.
The spline wheels can be turned similarly but you have a lot more choice of positioning.
And this damage/wear/rebuilding issue one of the reasons for an aftermarket "adjustable" pitman arm tie rod. (which is available or can be made from parts.)
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 11-17-2013, 08:23 PM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Unless ur short, like me, you'll be looking OVER it, SO, whut difference duz it make. Buster T. (l-:l>
"THE ASSISTANT GURU OF STUFF"
Old 11-17-2013, 08:36 PM   #6
freak
freak's Avatar
I just like things to look proper. When the steering wheel is not oriented properly it gives the appearance of the car needing a front end alignment IMO.
Old 11-17-2013, 11:35 PM   #7
BILL WILLIAMSON
Dog here, GOOD point, My Man, Ol' Bill leans to thu right, so's I git used to things KROOKEDY Is there a place thet can ALIGN Ol' Bill's KROOKEDY?
(OH! You gotta' Dog? & whut's ur first name?)
Buster T.
Old 11-18-2013, 12:12 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
You would be surprised how true that is. I have also noticed that A's with juice brakes also have the steering wheel a little off.
Old 11-18-2013, 12:49 AM   #9
Joe K
Joe K's Avatar
And cars that have had the front axle pushed back a little (curled around the spring perch usually) don't allow the steering wheel proper alignment either.
AND this even with the wheels aligned. (The wheels are aligned but not side by each of each other.)
Almost all axles seem to show this damage in greater or lesser degrees. Hard to find a straight one.
Joe K
Old 11-18-2013, 10:27 AM   #10
green30coupe
green30coupe's Avatar
A steering wheel can be off enough to block line-of-sight to the speedometer. Quite annoying!
Ed
LAW OF MECHANICAL REPAIR
ONCE YOUR HANDS BECOME COVERED WITH GREASE,
YOUR NOSE WILL ITCH AND YOU'LL HAVE TO PEE
green30coupe is offline   Reply With Quote
Old 11-18-2013, 10:35 AM   #11
rons49
rons49's Avatar
I believe that Joe is correct. X ... this way you can see the spark and throttle levers and through the wheel forward. That is what I read years ago.
rons49 is offline   Reply With Quote
