Old 08-30-2010, 11:04 PM   #1
Modelakid31
Send a message via AIM to Modelakid31
Default Interior molding color
Does anyone know what the correct maroon trim color code is. there are several dupont ford maroon and maroon color codes. which one is correct for a April 1931(early tudor standard) tudor sedan?
Modelakid31 is offline   Reply With Quote
Old 08-31-2010, 07:57 AM   #2
Aerocraft
Aerocraft's Avatar
Default Re: Interior molding color
I suggest that you look at the color chips and codes on www.tcpglobal.com. I believe the correct interior trim color for your Tudor is "Ford Maroon" and it has an "IM" code listed on the web site. TcpGlobal will mix the colors in lacquer, acrylic enamel, or acrylic urethane using either PPG or their own brand. I have been very pleased with what they have mixed for me and the colors have matched the MAFCA paint chips in sunlight. Gar Williams
Aerocraft is offline   Reply With Quote
Old 08-31-2010, 09:04 AM   #3
Modelakid31
I called Dupont and they gave me the correct fomulas and codes for the lombard blue and hessin blue. i didnt know with of there Maroon's was the correct color.
