Old 11-01-2013, 01:15 PM   #1
dave m
Default Head lite reflectors ?
Who is the best person for headlite reflector resilvering i want someone who is experienced with old fords---thanks
dave m is offline   Reply With Quote
Old 11-01-2013, 03:28 PM   #2
H. L. Chauvin
Default Re: Head lite reflectors ?
Hi Dave,
Bert's used to offer this headlight re-silvering service & they always did an excellent job; then they stopped ............ maybe because the person they subbed it out to quit doing it; however, they may have found somebody recently to do it ........... or, maybe they can recommend someone.
H. L. Chauvin is offline   Reply With Quote
Old 11-01-2013, 05:41 PM   #3
Dale G.
Dale G.'s Avatar
Riker Restorations, Craig Riker. 419-290-4442.
Dale G. is offline   Reply With Quote
Old 11-01-2013, 05:54 PM   #4
roadster
roadster's Avatar
NEWLY TOOLED ALUMINUM 1 BULB HEADLIGHT REFLECTORSFor Year(s): 28-31
Made from the original Ford prints. We have corrected the location of the center socket by moving it 1/16" off center, to allow you to correctly focus your headlights per the Ford service Bulletins. The word Top is stamped on the back of the gasket grove so you install the reflector correctly. The new reflector is aluminum plated, polished and sealed from the air. The aluminum finish has the same 92% reflection as the original silver plating, but silver will tarnish in a few months and your reflection will be reduced. The reflectivity of the cheap chrome reflectors is 65%, silver is 92% reflective, but reflectivity will diminish with in hours as tarnish and oxidation builds up on the surface. The sealed Aluminium process is 92% reflective and since it has been sealed it will maintain that 92% for many year to come. Minimum industry standard for headlight reflectors is 80%. Clean using a soft rag with soap and water. This is the one bulb style
Part #17940 NEWLY TOOLED ALUMINUM ... $ 89.95 NEWLY TOOLED ALUMINUM 2 BULB HEADLIGHT REFLECTORSFor Year(s): 28-31
made from the original Ford prints. We have corrected the location of the center socket by moving it 1/16" off center, to allow you to correctly focus your headlights per the Ford service Bulletins. The word Top is stamped on the back of the gasket grove so you install the reflector correctly. The new reflector is aluminum plated, polished and sealed from the air. The aluminum finish has the same 92% reflection as the original silver plating, but silver will tarnish in a few months and your reflection will be reduced. The reflectivity of the cheap chrome reflectors is 65%, silver is 92% reflective, but reflectivity will diminish with in hours as tarnish and oxidation builds up on the surface. The sealed Aluminium process is 92% reflective and since it has been sealed it will maintain that 92% for many year to come. Minimum industry standard for headlight reflectors is 80%. Clean using a soft rag with soap and water. This pair is aluminum plated two bulb.
Part #17950 NEWLY TOOLED ALUMINUM ... $ 89.95 try www.brattons.com
roadster is offline   Reply With Quote
Old 11-01-2013, 05:54 PM   #5
SteveB31
SteveB31's Avatar
We only quit offering them due to the cost getting higher and higher. the guy that did them for us was Acme Silver Plating. He does a great job.
Bob
Acme Silver Plating
Montrose, CO.
970-249-8996
Steve Becker
Berts Model A Center
SteveB31 is offline   Reply With Quote
Old 11-01-2013, 09:30 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Nickle plate then aluminum plate by Uvira same process as space telescopes
Old 11-01-2013, 09:58 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Brinkman's 651-698-8577. It was $55 each the last I heard.
