Old 10-05-2013, 02:51 PM   #1
RHD
RHD's Avatar
Default 'Early" banjo bolt configeration.
Has anyone noticed this bolt configuration before. When in the restoration business a few years ago, I had the fortune to restore two very 'early' cars with this configuration. Both were Phaetons with the emergency to the right (RHD).
Both cars had consecutive engine, frame and body numbers. No other vehicles here had a frame number except the very early cars. In 48 years I have only heard of two others.
This bolt configuration I would suggest is extremely rare and I have never heard it mentioned in any Ford Barn posts on rear ends.
Has anybody seen this configuration before?
R.H.D.
Silence is golden unless you have kids, then silence is suspicious.
RHD is offline   Reply With Quote
Old 10-05-2013, 06:12 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: 'Early" banjo bolt configeration.
This is the first I've seen or heard of such a bolt pattern.
Nice looking rear end............If you were a female, you'd slap me for saying that!
Old 10-07-2013, 12:14 AM   #3
Tudortomnz
Tudortomnz's Avatar
This is a Ford Canada modification sometimes seen on v.early Canadian Model A's.
Probably trying to strengthen everything up until the extra metal was added by Detroit.
The earliest Model A known in New Zealand, CA 67, owned by Bick, has this type rear end with extra bolts.
Tudortomnz is offline   Reply With Quote
Old 10-07-2013, 02:33 PM   #4
Jim Parker Toronto
Jim Parker Toronto's Avatar
I have the same one in my June 28 Roadster....(Canadian car..)
Jim Parker Toronto is offline   Reply With Quote
