Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 09-04-2013, 07:20 AM   #1
krackerjack1951
krackerjack1951's Avatar
Default 51 ford automatic 331 ratio rear
City: nc
State: nc
wanting 331 ratio rear for 51 ford automatic..is there any out there?
krackerjack1951 is offline   Reply With Quote
Old 09-11-2013, 10:19 AM   #2
ThomasN
ThomasN's Avatar
Default Re: 51 ford automatic 331 ratio rear
Would a 53 be the same? If so I may be able to help you?
T
ThomasN is offline   Reply With Quote
Old 09-13-2013, 05:56 AM   #3
krackerjack1951
tom ,,maybe,, a wagon might have a 331 ratio...most ford automatics have either 354 or 331 ratio.straight drive would have about 411 ratio....most rears have an ID tag on them with the ratio.. located on pumpkin bolt>>just need ring and pinion! thx G
Old 09-13-2013, 08:32 PM   #4
BOSSY
BOSSY's Avatar
49 to 55 should be the same exp. wagon are differend.
BOSSY
BOSSY is offline   Reply With Quote
Old 09-15-2013, 09:53 AM   #5
ThomasN
ThomasN's Avatar
It will be a real task for me to check it out, but I will give it a shot this week. It is sitting on the ground.
