Old 08-23-2010, 11:44 AM   #1
700rpm
700rpm's Avatar
Default Removing rust stains from radiator-SOLVED!
Yesterday I took my A out for a long drive; at about 30 miles my radiator started spitting out thick brown gunk from the filler spout. (I know what the problem was and I've dealt with that.) I was in a rural area with no running water to flush it out, so I wiped it out and washed it as best I could with some bottled water I had. By the time I got home, after a couple similar incidents, my radiator was well stained by the rusty residue. I scrubbed with a toothbrush and hot soapy water, but only to minimum effect. Can anyone suggest a good method for cleaning this junk off my radiator and getting a good black back? The radiator was just reworked and repainted at a radiator shop, and it was looking good till yesterday.
