Old 05-11-2010, 03:09 PM   #1
V4F
V4F's Avatar
Default model 'a' 4 speed trans
i have lost my info on who makes the 4 speed trans for the "A"s . it fits into stock location & 4th is overdrive . can some one please help me .. steve
V4f
V4F is offline   Reply With Quote
Old 05-11-2010, 03:26 PM   #2
V4F
V4F's Avatar
Default Re: model 'a' 4 speed trans
i thought it was mitchell , but not in his catalouge ............. steve
V4f
Old 05-11-2010, 03:53 PM   #3
Thomas
Steve; We use a 1985 Ford Tk 150 4 speed. A machine shop in Mich will convert it for you. e-mail for the shop. [email protected]
Thomas is offline   Reply With Quote
Old 05-11-2010, 04:06 PM   #4
Logan
Logan's Avatar
Gary Bernard makes one here in Ft. Worth. We have about 25,000 on his without a problem. And i know a lot more people who have his with a lot more miles, and its still going strong. Email me for contact info.
Logan is offline   Reply With Quote
Old 05-11-2010, 04:39 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I think Jim Parker in Canada makes the kit.
Old 05-11-2010, 05:28 PM   #6
Bob K. St Paul
Bob K. St Paul's Avatar
Try www.modelaonly.com
Bob K. St Paul is offline   Reply With Quote
Old 05-11-2010, 07:43 PM   #7
Jim Parker Toronto
Jim Parker Toronto's Avatar
Thanks for the plug Tom, and I am doing ONE, and its for me! Doing brakes for fellows up here keeps me busy enough! I need some free time too, trying to drive the wheels off my Roaster ya know!
Jim Parker Toronto is offline   Reply With Quote
Old 05-11-2010, 09:33 PM   #8
AL in NY
AL in NY's Avatar
There is another person who makes kits to do this install. His name is Ken Parker in Van, Texas and he posts on fordbarn. His contact information is: Phone - 903-963-1650 or e-mail ([email protected]). The kits run around $2700 complete. I have done this install myself without a kit and I wrote an outline of the procedure I used. I can send that to you if you are interested. Probably cost you slightly less than half the $2700 to do it yourself.
AL in NY
AL in NY is offline   Reply With Quote
Old 05-12-2010, 07:16 AM   #9
kenparker
kenparker's Avatar
Thanks for the plug Al. Ken
kenparker is offline   Reply With Quote
Old 05-12-2010, 11:20 AM   #10
V4F
V4F's Avatar
thank you all . i found & contacted a person . so again ... thank you all !! .. steve
V4f
Old 02-28-2015, 06:09 PM   #11
namvetmike
Please send me the info on your transmission conversion.
[email protected]
namvetmike is offline   Reply With Quote
Old 02-28-2015, 06:52 PM   #12
harleytoprock
Al, I would also love to see your 4 speed conversion outline. Thanks!
[email protected]
harleytoprock is offline   Reply With Quote
Old 02-28-2015, 09:24 PM   #13
Floats
Floats's Avatar
Hi Al,
Could I have one as well please.
Regards
Chris
Cape Town
cfm65 at me.com
Floats is offline   Reply With Quote
Old 03-01-2015, 10:39 AM   #14
machine girl
modelaonly.net building these for over 25 years.
machine girl is offline   Reply With Quote
Old 03-01-2015, 11:31 AM   #15
Chris Haynes
Chris Haynes's Avatar
Sounds like the first step in making a Model A into a street rod.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 03-01-2015, 11:57 AM   #16
Ron W
Ron W's Avatar
Usually a high compression head is the first step. I did my own trans (similar to Al's) and it makes the "A" a pleasure to drive. Ron W
Ron W is offline   Reply With Quote
Old 03-01-2015, 02:10 PM   #17
bgarrett
bgarrett's Avatar
The 4 speed is a completely different transmission from the 3 speed with overdrive.
Upgrading parts on a car does not make it a streetrod. It simply makes it more useable
bgarrett is offline   Reply With Quote
Old 03-01-2015, 02:25 PM   #18
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Well not so fast, ...."more usable"?? Model-As, --amazingly to some, --were WERE very usable for some 50+ years until someone (erroneously) convinced other peers that the original transmissions were not usable any longer.
And so we are clear, "upgrading" is perfectly acceptable on a 'Restored' vehicle if it is undetectable. A high-compression head can be undetectable, insert bearings inside the engine is considered undetectable, a hi-speed ring & pinion is considered undetectable. A F-150 transmission IS detectable ...even in Helen Keller's eyes!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-01-2015, 03:13 PM   #19
AL in NY
AL in NY's Avatar
Brent, the F150 is only detectable if you crawl under the car and look. And it is a much more concealed upgrade then the Mitchell overdrive unit. And 99.9% of the people who look at the car, won't know it's there!!!
AL in NY
Old 03-01-2015, 03:39 PM   #20
Tom Wesenberg
What we need is a nice 4 speed overdrive that fits inside the stock tranny case.
