Old 08-13-2013, 06:17 PM   #1
Bobs32
Bobs32's Avatar
Default Blue see thru spark plug wires
When I rebuilt the '48 Mercury engine in my dad's '32 he had blue see thru spark plug wires on it. I have seen red ones for sale but as of yet have not see the blue. Does anyone know where I can find the blue ones ?
Thanks in advance for any info.
Bobs32 is offline   Reply With Quote
Old 08-14-2013, 07:48 AM   #2
Blu Dice
Blu Dice's Avatar
Default Re: Blue see thru spark plug wires
OOOOh, I would like those too - I was planning to replace my wires this weekend.
Blu Dice is offline   Reply With Quote
Old 08-14-2013, 07:03 PM   #3
Talkwrench
Talkwrench's Avatar
Never seen anything like see though plug wires.. Wonder if there is a YouTube vid??
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 08-14-2013, 07:25 PM   #4
Ross F-1
Ross F-1's Avatar
http://www.speedwaymotors.com/Red-7m...0-Ft,5117.html
Transparent would be a better description.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-15-2013, 04:56 AM   #5
oldskool
oldskool's Avatar
red is available seen natural clear ones back in the day,would love to have green clear myself
oldskool is offline   Reply With Quote
Old 08-15-2013, 05:58 AM   #6
SUHRsc
SUHRsc's Avatar
I wonder if you could take the clear ones and dye them??
I used to die plastic parts on radio controlled cars. Just normal RIT dye.
You'd probably have to keep the ends out of the water but if you did the whole roll at once it wouldn't be a big problem to lose a little bit.
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 08-15-2013, 07:18 AM   #7
36rgtop
36rgtop's Avatar
Word of advice - These transparent/solid core wires should be used for points only ignitions. Solid core wires mess up electronic ignitions.
36rgtop is offline   Reply With Quote
Old 08-15-2013, 12:19 PM   #8
Bobs32
Bobs32's Avatar
I should of never let the old ones get away from me. I'm sure I could of found someone to rework them for me. Oh well.
Old 08-15-2013, 01:23 PM   #9
Carl
...there you go...another good idea for some one; create clear see thru wires in different colors; you could probally sell a bunch!
Carl is offline   Reply With Quote
Old 08-16-2013, 08:41 AM   #10
Bobs32
Bobs32's Avatar
right you are !
Old 08-16-2013, 09:20 AM   #11
jkeesey
jkeesey's Avatar
I have seen them on several motorcycles but never a car.
jkeesey is offline   Reply With Quote
Old 08-16-2013, 09:40 AM   #12
Blu Dice
Blu Dice's Avatar
So there is a source of bulk wire I bet!?
Old 08-16-2013, 12:42 PM   #13
jkeesey
jkeesey's Avatar
Ive been trying to find a source but cant. Found out that also makes spark "wires" using neon tubes to transfer the electricity so they actually light up and glow when running.
Old 08-16-2013, 02:28 PM   #14
hbwoody
How about these?
http://www.sevensinschoppers.com/category_s/162.htm
hbwoody is offline   Reply With Quote
Old 08-16-2013, 05:10 PM   #15
Brian
Brian's Avatar
hbwoody,Now that is a very good first post. That will have answered the original posters question.
Welcome!
Brian is offline   Reply With Quote
Old 08-16-2013, 08:46 PM   #16
Blu Dice
Blu Dice's Avatar
2 - 21" pieces @ $45.00 x 4 = $180.00 WOW!
Not sure 21" is long enough for the driver side.
It's a start.
Old 08-16-2013, 09:13 PM   #17
Jack E/NJ
Jack E/NJ's Avatar
What'sa matter black?
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 08-17-2013, 09:31 AM   #18
Bobs32
Bobs32's Avatar
Thanks hbwoody !
