08-01-2013, 11:44 PM | #1 |
1956 Mandarin Orange
I need a color code for 1956 mandarin orange. Previous posts information has been of no use trying to get a urethane paint formula in ppg or dupont. Please help! The sunliner is almost ready!!
08-02-2013, 05:36 PM | #2 |
Re: 1956 Mandarin Orange
The only codes I can come up with are:
Ford code: N PPG code: 60211 |
08-02-2013, 09:02 PM | #3 |
its no use you cant get anything in urethane at least I couldn't.all the old codes are useless.dupont gives you the closest thing which is atlas orange.i was not happy.in this day and age I couldn't believe they couldn't come up with something.
08-09-2013, 09:04 PM | #4 |
Google autocolorlibrary.com put in your year make and all the 56 colors will come up then click on the color and it give the formulas.
BOSSY |
08-12-2013, 06:05 PM | #5 | |
I checked them out and they do have a good selection, prices don't sound to bad. My concern was how well they mixed the color , good or bad match ? After it has been mixed and shipped out to the customer i believe it will need mixing again so how should that be done ? I have had my local building center do it in the past with their shaker but most won't do it. Would it be just as good to use three mixing containers to mix one gal. By mixing and dumping from one container to the other ?____ .
64 Futura , bought new. 56 ford fairlane , bought about 30 years ago. 35 chevy street rod , started building in 2000. |
08-14-2013, 07:15 AM | #6 |
08-14-2013, 08:21 AM | #7 |
I took a small part, went over it with polishing compound by hand, then two coats of wax. Held it in the sunlight to scan, the new paint was mixed and it matched perfectly.
08-15-2013, 07:46 AM | #8 |
BASF was able to provide the correct color for the Sunset Coral on my 58 Edsel when NO ONE else could. My supplier called in the color, Edsel paint code and year and 30 minutes later I had a quart. Turns out it was a perfect match.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
