Starting an Engine that hasn't run in two years?
This place has become a great resource for me, especially since I am still in the learning phase of how everything on a Model A works.
What steps should I take in order to get an original Model A engine to run good? I am not new to motors, just new to older style engines. The engine starts right now as it sits but it runs rough and backfires quite frequently.
Local Model A shop said to check the compression before I go too much further. I was planning on buying new plugs and connectors, flush radiator, change oil, drain fuel and blow out the lines, clean the carb, and then give it a go. I am assuming because it starts that all my ignition components are working properly, its just a matter of getting everything tuned in. I have a hunch that the rear cylinder was misfiring because the spark plug looked severely corroded and warped, maybe a sign that it was running too lean at one point?
Anyways, any insight from you experts would be greatly appreciated!
