Old 07-21-2013, 05:47 PM   #1
saltman
Default Front bumper arm installation
Just tried to mount a new set of front bumper arms for my 28 Coupe. After installation, I discovered that the right arm is not only about 2 1/2" bent too far out but, the front holes are too small for the front clamps. I have measured the bend of the arm with regard to my frame, the bumper and the other arm many times and come up with the same result. I measured my old clamp bolt diameters and they appear to be 9/16". The holes on the new arms appear to be 1/2". Can someone verify or deny that my old clamps or too big or the arm holes are too small on the new arms? Is there a variance between years as far as clamp bolt/arm hole sizes? SALTMAN
PS: 'Every time' .. I try to install a new part on my Model A, its like trying to stick a large square peg into a much smaller round hole... nothing ever seems to work...!
saltman is offline   Reply With Quote
Old 07-21-2013, 06:12 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Front bumper arm installation
No offense, but is it on right?? And not reversed??
Paul in CT
Old 07-21-2013, 09:20 PM   #3
jw hash
jw hash's Avatar
you are correct they are 9/16" and if you drill it out go one drill size over.
jw hash is offline   Reply With Quote
Old 07-21-2013, 09:30 PM   #4
SeaSlugs
SeaSlugs's Avatar
are these bumper arms repro new or new to you origionals?
yea they should curve upward a tad
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 07-21-2013, 10:50 PM   #5
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I'm not sure what the alloy is, but they don't like to be bent, even with heat, which probably isn't a good idea. I ended up finding some good originals, and stopped wasting my time getting them to "match".
Old 07-27-2013, 05:00 PM   #6
Timberbeast
Timberbeast's Avatar
Could it possibly you have a 30/31 arm on one side, they curve more to match the arched contour of the later bumper.
Timberbeast is offline   Reply With Quote
Old 07-27-2013, 09:28 PM   #7
scott30
Check to see if the front frame horns are bent, twisted etc. This will cause the arms to be at a strange angle.
scott30 is offline   Reply With Quote
