Old 07-16-2013, 09:27 AM   #1
EJGjr
Question distributor play
Question please advise.How can I check my distributor for play when it is on the engine.
EJGjr is offline   Reply With Quote
Old 07-16-2013, 10:57 AM   #2
Dave in Boise
Dave in Boise's Avatar
Default Re: distributor play
there are 2 types of play..
Rotational (twist the rotor clock and counter-clockwise) which will give you an idea of timing play and slop in your distributor gear and midshaft. This is generally pretty common to have 5-10 degrees of play. This can be fixed by replacing the distributor shaft(s) if you have the 2 piece units below the distributor body
lateral (move the rotor side to side) which will give you varying spark gaps between the rotor and the distributor body as well as differing and random) point gaps if the movement is large enough) Lateral movement should be as near to 0 as possible. If there is lateral slop, it is time to put in new bushings in your distributor.
Hope this helps.
Dave in Boise
Dave in Boise is offline   Reply With Quote
Old 07-16-2013, 12:03 PM   #3
EJGjr
Thanks Dave I think it is time work on the distributor
Old 07-16-2013, 12:21 PM   #4
Brentwood Bob
watch for cracks in the housing next to the bushing. There are 2 widths of the channel the top plate rides in. The top plate also wears on the inner surface where it contacts the housing. Go with the 2 piece shaft.
Bob
Brentwood Bob is offline   Reply With Quote
Old 07-16-2013, 12:59 PM   #5
TinCup
TinCup's Avatar
Don't forget the cam drive gear. I see these all the time with teeth that are so worn they appear to be sharpened. Any slop here and it just transfers to the distributor gear.
TinCup is offline   Reply With Quote
Old 07-17-2013, 07:54 PM   #6
EJGjr
Thanks folks your advise has been great thanks again
Old 07-18-2013, 12:20 PM   #7
Brentwood Bob
Tell us what you found, We can always learn from your experiences. Thanks, Bob
Old 07-18-2013, 01:45 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Brother, Bob, I have a long shaft dist that runs very "true" & apparently has a perfectly straight shaft. I feel that this is a plus, as it eliminates an extra slot connection to lessen rotational play. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-18-2013, 03:48 PM   #9
Marshall57
There are two kinds of play in the distributor that have continued to plague me. First is the bushing being worn and the second and less talked about is the fit of the top plate in the distributor body. There is a real problem when buying new parts for the distributor but the top plate fit is not always taken into account and makes a huge difference. I have had to mix and match to get a plate and a body that didn't have an unreasonable amount of play. Try holding on to the top plate and moving it back and forth, some that I have seen are so sloppy that they could never hold a point gap. This might also be a wear problem on an original distributor if it has been in service for all those years and has seen untold adjustments of the timing. This of course does not address the gears which have been addressed above.
Marshall57 is offline   Reply With Quote
Old 07-18-2013, 04:56 PM   #10
ford3
i worry more about the play in the crank and cam gear, ive seen some cranks move over 25 degrees before the rotor turns, when that happens there is no way to get an accurate timing, take the dist cap off and turn the crank shaft back and forth and see how far it turns before the rotor moves, should be very little if any play before the rotor moves, that really works on engines with timing chains
ford3 is offline   Reply With Quote
Old 07-18-2013, 05:42 PM   #11
Brian T
Brian T's Avatar
There is an easy fix for loose top distributor plates, picture here courtesy of Marco Tahtaras.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 07-18-2013, 06:09 PM   #12
Marshall57
That might work, I will have to take another look,,
Thanks
Old 07-18-2013, 09:57 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
I always grease the center hole and tabs on the top plate, to help slow wear.
Old 07-22-2013, 08:21 PM   #14
EJGjr
Thanks for all the input .I found verticle play as well as side to side ,bushings are bad also in need of thrust washers.Thanks folks for the help.
Old 07-22-2013, 08:29 PM   #15
Mitch//pa
your welcome
Old 07-25-2013, 03:31 PM   #16
Marshall57
Marco was exactly correct, tryed it and it worked like a charm.
First time I have had one that was perfict..
Thanks again.
