07-07-2013, 08:23 AM | #1 |
Vapor lock
Gotcha..........................
I installed an electric fuel shutoff on my indented 31 Tudor when I first bought it. It's been trouble free and no leaks. For the past year I've been fighting what some of you may call "vapor lock". No or reduced fuel flow. Stops running, pull to the side of the road, crack the fitting at the carb and "magic", fuel flow. I even covered the fuel line with the orig style wire loom fabric. Last Saturday on the way to a cruise (didn't make it) it happened about 5 times. I let the car sit for a week (too hot/humid). Yesterday I went out and ck'd for flow, strong flow from the tank, little to no dribble from the valve. I dis-assembled the valve and found the solenoid "sticking", flushed it out good with carb cleaner, re-assembled and now have the same rate of flow from the valve as from the tank. Luckily, I have no dirt/rust in my tank (thank You God !) Maybe this experience will help someone else. Paul in CT |
07-07-2013, 08:41 AM | #2 |
Re: Vapor lock
ur mean u got me::: but a good tip.
07-07-2013, 09:01 AM | #3 |
Re: Vapor lock
Dare I say this......
Another modern improvement affecting the reliability of the car. |
07-07-2013, 11:01 AM | #4 |
Re: Vapor lock
I posted this because I can't be the only one who bought and installed one so I didn't have to keep opening and closing the hood, or people that have a bad tank valve inside the car. FWIW
Paul in CT |
07-07-2013, 12:33 PM | #5 |
Re: Vapor lock
I have one. Thanks for the tip.
John |
07-07-2013, 02:05 PM | #6 |
Re: Vapor lock
07-07-2013, 02:13 PM | #7 |
Re: Vapor lock
But there y'all go confusing everyone with the facts! Remember, it has to be vapor lock is what the cause is, ...the other items are just post-contributing factors but not the initial cause.
07-07-2013, 03:49 PM | #8 | |
Re: Vapor lock
I also don't understand the motivation to make "fun of" a real experience that has happened to both myself and others. Surely the point of this forum is to share experiences and help people. That's why I'm here anyway. Marc Marc Last edited by marc hildebrant; 07-07-2013 at 04:07 PM. |
07-07-2013, 06:42 PM | #9 |
Re: Vapor lock
I don't think one can blame Paul for installing the electric shut-off. If you want to turn off the fuel every day then walking around the car to open the hood can be a real PITA. I don't think that was one of Fords better ideas. Maybe some don't turn off the fuel.
Vapor lock has been discussed ' at length'. Maybe its real, maybe not. Its certainly real on other types of vehicles. Its been mentioned that maybe ethanol is a cause. So, just for the heck of it, I made sure the fuel line had a downward slope to the carburetor and I made a little heat shield out of some heavy roof flashing. It mounts to the left 'through' manifold bolt and one exhaust clamp double nut. It fits as close to the valve cover and carburetor linkage as possible and extends below the exhaust clamp and carburetor inlet by about 4 ". My thought was about trying to keep manifold and pipe heat away from the carburetor. Just thought I'd put this out here, don't know if it works because I did not had vapor lock issues. At least, not yet anyway. |
07-07-2013, 07:32 PM | #10 |
Re: Vapor lock
Paul, today I have just the opposite problem, mine won't shut off. I have the one that goes between the tank and firewall. I installed it because the air conditioning completely blocks access to the OEM valve. AND, of course, I have a full tank and not enough gas cans to siphon the tank. My carb leaks about a drop a minute, so the garage smells and I'm going to have to fix the valve, once I drive most of the gas out.
07-07-2013, 07:37 PM | #11 |
Re: Vapor lock
I struggled with the "vapor lock" concept for about a year because I was in denial about all of the "fines" of rust settling in the sediment bowl, plugging the micro filter and keeping the needle valve closed. After accepting the denial as the real problem, and removing and reconditioning the tank, (major job) the "vapor lock" has gone away and the engine no longer stalls because the fuel is not contaminted. A clean carburetor is a happy carburetor and also makes the driver happy. Tom
07-07-2013, 08:22 PM | #12 |
Re: Vapor lock
My vapor lock symptons were caused by a gas cap.When you tightened the cap some times the gasket would rotate and cover up the vent hole. Then I would have vapor lock symptons . If I filled to full and the gasket turned and blocked the vent hole then the vapor lock symptons started.First day one hundred miles into a 1,000 mile trip I started having vapor lock . Second day finally figured out what was causing the vapor lock . Backed off on the gas cap and no more vapor lock . Replaced gas cap and all is good . Car had stalled on me many times ,sometimes in dense traffic , with vapor lock symptons.
07-08-2013, 06:13 AM | #13 |
Re: Vapor lock
I thought my problem with the A was vapor lock but after going though system it was caused by a faulty new condenser. Replaced faulty one with NAPA's best and it ran great again...
07-08-2013, 06:44 AM | #14 | |
Re: Vapor lock
brent is one of the most valuable assets to this site in expertise and experience. Last edited by Mitch//pa; 07-08-2013 at 06:58 AM. |
07-08-2013, 08:19 AM | #15 |
Re: Vapor lock
Mitch,
I agree that Brent posts very helpful comments....however, the use of 'Vapor Lock" in this discussion by the original post and follow on comments by Brent comes across as a needless "snarky" comment. "Vapor Lock" has been blamed as a cause of other real problems in the past, but so has many other things at first. For example, how many times does the carburator get blamed for ignition problems ! I regard this forum as a "safe place" where you can discuss problems and such with your car. Hence, members who believe that 'Vapor Lock" is a problem should be as free to post the comments as those who have trouble with electron flow. That's how I see it. Marc |
07-08-2013, 08:41 AM | #16 |
Re: Vapor lock
After reading several posts in which a faulty gas cap was blamed for a problem that turned out to be caused by something else, I have come to the conclusion that gas caps don't exist.
07-08-2013, 03:20 PM | #17 |
Re: Vapor lock
How is it possible to get " vapor lock" in a gravity feed system???? Please someone explain this as I can't imagine how it can occur. Thanks : Bruce
07-08-2013, 03:24 PM | #18 |
Re: Vapor lock
Maybe gas caps don't exist, but, every now and again a faulty one rears its ugly head !
07-08-2013, 05:50 PM | #19 | |
Re: Vapor lock
I believe Paul used that opening line with tongue in cheek to antagonistically engage in a topic that he knew would likely draw a grin from most, ...and be controversial to a few. So I guess it is OK for him to say something controversial however you feel like it is improper for me to making an equally controversial reply in jest. Maybe the difference is you don't like my comment because my opinion does not align with your views. Now that does seem kinda petty, don'tcha think? Again, what's the use?? With regard to your comment about carburetors getting blamed for ignition problems, ...well from my vantage point, it does not very often if some one truly knows how to properly diagnose. Often times, it would appear the ones that should be receiving the advice do not want to accept what the facts are! That's OK in my view because it is indeed a "safe place" here. . |
07-08-2013, 06:05 PM | #20 | |
Re: Vapor lock
I don't like paying a buck a gallon extra to leave the crap out of the gas, but it's much better than fighting all the problems caused by ethanol. BTW, people can say it doesn't happen or call it what they want, but for me it's real and I call it vapor lock, because the gas turning to vapor is the problem. |
