Old 07-01-2013, 08:34 PM   #1
Richard/Tennessee
Richard/Tennessee's Avatar
Default 16" wheels on 30 tudor
What tire brand and size r u running ?? search wasn.t much help...thks for info.......
Richard/Tennessee is offline   Reply With Quote
Old 07-01-2013, 09:00 PM   #2
bettlesr
bettlesr's Avatar
Default Re: 16" wheels on 30 tudor
My tires are Dunlap Grantrek 215/70 R16. They are run tubeless.I have about 12,000 miles on them.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 07-01-2013, 09:30 PM   #3
johnsor
I put on 35 Ford 16" spoke wheels with 6:50 x 16 Firestone ww on my 30 Roadster. I put the 6:50's on because they are the same O.D. as the stock 19's thus engine RPM's are not increased. I run 20-22 psi for a smooth ride and great handling.
johnsor is offline   Reply With Quote
Old 07-01-2013, 09:33 PM   #4
Gary WA
Gary WA's Avatar
Just put a set of Lester 600-16 from Lucas Classic tire and they ride great compared to the old hard tires I had 147.00 ea +_sh
www.whidbeymodelaclub.com
Old 07-02-2013, 05:09 AM   #5
willobs
Do most people run tubeless? arent most radial tubes with the stem in the wrong area for a 16 in ford wheel?
willobs is offline   Reply With Quote
Old 07-02-2013, 08:29 AM   #6
johnsor
My 6:50 x 16's are bias ply using inside flaps and tubes. Supposedly, and it's been said that a radial tire is not suited for a spoked wheel as the rims are not ridged enough for a radial tire which flexes a good deal, but I don't know if that's factual. Besides I could not find 6:50 radials.
Old 07-02-2013, 05:48 PM   #7
1931 flamingo
1931 flamingo's Avatar
I've seen others post that they're running 195/80R16, which I believe is equivalent to 600/16.
Paul in CT
Old 07-02-2013, 06:07 PM   #8
columbiA
Ive used 6.00-16,s on 35 wheels years ago but they dont look right to me & it felt like I went from a 3.78 ratio to a 4.11.I soon changed back to 19,s & all was well.6.50-16,s might be same OD as the 5.00-19,s but they still dont look right.An A doesnt realy look like an A unless it has the correct wheels on it.
columbiA is offline   Reply With Quote
Old 07-02-2013, 08:45 PM   #9
Duffy1
No problems running tubeless 1935 16`s on my s/w .
Duffy1 is offline   Reply With Quote
