06-22-2013, 05:40 PM | #1 |
Fix for Old Man Problem #21
Sometimes (often) we forget to turn back the switch on our directionals when we don't have the canceling type.
I installed a light in the dash panel (1929 type) and connected it to 2 diodes and back to the cowel lamps that I use for front signals. Works great -- should have thought about this sooner. Lee |
06-22-2013, 06:24 PM | #2 |
Re: Fix for Old Man Problem #21
Could use some clarification. Are you feeding the additional dash light from the cowl light turn signals through diodes? If yes, I assume the resultant flashing dash light reminds you that the turn signals are still on. What type/rated diode did you find that works well?
06-22-2013, 06:54 PM | #3 |
Hi!
I also constantly forgot to turn mine off, same with high beams. As the headlights are halogens, they are quite bright. I have a beeper on the flashers but still sometimes the noise of the car is louder than the beeper. What I did, was to first change the daskboard screws to Stainless philips head screws and then drill a small hole through them. I then got a couple of small leds, added a dropping resistor to one lead of each and slid heatshrink tube over the connections. When they are lit, the highbeam indicator is a dim blue led and the flashers have a brighter green led. The pictures show them light and out. The flasher led is feed from the pilot terminal on the mechanical flasher. The rear flashers are in the tail lights and the front are double filiment bulbs in the cowl iights.
1965 Lotus Elan S2 1930 Model A Sport Coupe |
06-22-2013, 06:56 PM | #4 |
Sorry for the lack of clearity, yes the cowel lights feed through the diodes (not sure of the value-but the Radio shack sales person said they would handle up to 200 volts). Physically they are about 1/8" by 1/4".
They do blink each time the cowel light blinks. The diodes prevent backfeed that would cause both sets of lights to flash when used. Otherwise it would require 2 seperate lights. Lee |
06-22-2013, 07:36 PM | #5 |
Very clever and very clean installation.
06-22-2013, 07:36 PM | #6 |
Cowtown A's |
06-23-2013, 10:58 AM | #7 |
Here's a novel fix suggested by a friend:
"a smoke alarm buzzer works great for ooold folks in a noisy Model A. I use one in the middle of a jumper lead for circuit testing also. They're real small."
06-23-2013, 11:07 AM | #8 |
If you would like a schematic of what Minn-Tex Lee did, send me an email as have the schematic for both positive and negative ground for a buzzer, but could change to an Led with a dropping resistor or a bulb in place of the buzzer. [email protected]
06-23-2013, 12:59 PM | #9 |
This old man(87) uses hand signals. It is hard to forget to bring your left arm in...
06-23-2013, 04:56 PM | #10 |
