Old 06-20-2013, 07:05 AM   #1
Dan Ewing
Default What is correct location of bows on top irons
Would anyone be so kind as to provide me with a bit of guidance on locating the 2nd and 3rd top bows on new top irons for 31 Deluxe roadster?
Specifically, what should the distance be from the tip end of each respective bow to the centerline of the first screw hole nearest to the tip? I am making the assumption that the legs of each respective bow are the same length. The bows were bought from LeBaron Bonney.
I have the old bows as a template that I can use in a pinch but not sure the accuracy of the previous installation. I am also installing a new LB top.
Thank you for any help you may be able to offer.
Dan Ewing is offline   Reply With Quote
