Old 06-18-2013, 07:23 PM   #1
buddyholley19
Default range on a full tank of gas 10us gal
Fellas how far can you go on a full tank of gas.its hard to tell when your gauge bouces all over the place thanks in advance
buddyholley19 is offline   Reply With Quote
Old 06-18-2013, 08:00 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: range on a full tank of gas 10us gal
The most I have gotten was 245 miles and it was very empty, the gauge had stopped moving miles before ---I though I was going to run out but made it , this was on a trip and I was averaging fuel mileage in the low 20s at 60 mph+ ---your mileage may vary --- now I don't keep track and I usually don't fill all the way, 20$ gets me more than 100 miles of parades and local driving, I run the mixture on the lean side and use a lot of advance ---most times all of it
Old 06-18-2013, 08:06 PM   #3
SDJason
SDJason's Avatar
I never ran the tank dry, but DO keep track of my mileage - no matter what I do, I get 14 mpg (city driving - I won't take it out on the highway) - so whenever I get close to putting on 130 miles or so, I stop to fill up.
SDJason is offline   Reply With Quote
Old 06-18-2013, 08:09 PM   #4
Louis
Depends on your driving, if you are getting 18 mpg, and you fill up with 10 gal's, your going to be walking in about 180 miles .
I would fill up aprox. every 150 miles .
I've suffered a great many Catastrophe's in my life.....most of them never Happened.
Louis is offline   Reply With Quote
Old 06-18-2013, 08:31 PM   #5
H. L. Chauvin
Humble Opinion:
1. If you are second guessing Model A gas mileage, experience shows it varies based on so many factors, & there are far too many to list herein.
2. Suggest making a wood measuring stick, minimum size about 3/4" x 5/8" x 12" long, with the stick marked on one side with horizontal marks & numbers similar to markings on a tire gauge as follows, to indicate how many gallons are in your tank:
3. Measuring from the bottom of the 12" long stick at (O) gallons, the height for each added gallon of gas appears to be approximately as follows:
(1) gallon @ 1-1/2" from the bottom of the stick; (2) gallons @ 2-1/2"; (3) @3-3/8"; (4) @ 4-3/16"; (5) @ 5"; (6) @ 5-13/16"; (7) @ 6-11/16"; (8) @ 7-1/2"; (9) @ 8-9/16"; & (10) gallons @ 10-1/16" from the bottom of the stick.
4. Posted this about 6 days ago -- it was copied from another author in a former post -- asked a question about 1928-1929 tank measurements vs. 1930-1931 & received no reply -- it cannot be too far off if any.
5. Check gauge now & then while traveling long or short distances -- just an inexpensive simple marked wood stick that does not require a calculator at every stop, and beats walking 10 miles to the nearest gas station when one runs out of gas.
Hope this helps to prevent getting stranded on the highway with an empty tank.
H. L. Chauvin is offline   Reply With Quote
Old 06-18-2013, 09:08 PM   #6
spdway1
spdway1's Avatar
I fill every 100 miles.
spdway1 is offline   Reply With Quote
Old 06-18-2013, 10:20 PM   #7
H. L. Chauvin
Appears to be far more accurate information in the recent replies in the former Thread entitled:
Gas Tank Measuring Stick
Old 06-19-2013, 08:37 AM   #8
Jim/GA
Jim/GA's Avatar
When planning long driving tours, I plan a fuel stop every 100 miles or so (determined by locations of stations, obviously). That handles even the lowest MPG cars in the group, while others only put in 5 or 6 gallons. And we all need a rest break around that time anyway!
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 06-19-2013, 07:01 PM   #9
SHEC
SHEC's Avatar
On average our '30 Deluxe Coupe knocks out 20.4 mpg. My Dad was a banker so he loved his record keeping - must have rubbed off on we 3 lads as I do the same.
Be well -
SHEC
SHEC is offline   Reply With Quote
Old 06-19-2013, 07:11 PM   #10
Napa Skip
Napa Skip's Avatar
"Fellas how far can you go on a full tank of gas?"
Depends on how many cups of coffee I had before leaving home. Nowadays, not that far...
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
Old 06-19-2013, 07:18 PM   #11
Mitch//pa
skip you need one of these
Old 06-19-2013, 07:21 PM   #12
Napa Skip
Napa Skip's Avatar
Mitch 1 Skip 0
Skip Keyser
Napa Valley A's
MAFCA (since 1978)
MARC (since 1977)
Old 06-19-2013, 07:23 PM   #13
spdway1
spdway1's Avatar
Thats an small opening
Old 06-19-2013, 09:52 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
What is that.............a spare gas container?
Old 06-19-2013, 10:49 PM   #15
Dusty
Dusty's Avatar
Small opening my a$$, I could stuff everything in there and have room for a buddy
Living small in WV
dusty
Dusty is offline   Reply With Quote
Old 06-19-2013, 10:56 PM   #16
stallerl
stallerl's Avatar
You guys are hilarious!
I like the idea of a measuring stick. Simple and it works. I had one for my Model T years ago. Fortunately my gas gauge works in my Model A.
stallerl is offline   Reply With Quote
Old 06-19-2013, 11:34 PM   #17
spike
I need a deeper bottel...lol
spike is offline   Reply With Quote
Old 06-20-2013, 07:06 AM   #18
Richard Wilson
Richard Wilson's Avatar
I agree. 100 miles (or 2 1/2 hours) is a really good number between tour stops. I always planned for a gas/bathroom stop every 80 to 100 miles for club tours here in the mountains.
Richard Wilson is offline   Reply With Quote
Old 06-20-2013, 01:15 PM   #19
Don S
I saw somewhere recently that Henry designed the gas gauge to read empty,whilre there was still 1 gallon of gas still in the tank,for me good for 18 miles.
Don S is offline   Reply With Quote
Old 06-20-2013, 02:57 PM   #20
kp
kp's Avatar
I'm like Napa Skip,couple cups of coffee and stoppin soon,so gasoline never gets low.I knew one guy that ran a garden hose to the outside ,put a funnel on the end inside,he had an extra tank .
kp is offline   Reply With Quote
