Old 06-18-2013, 10:16 AM   #1
David Conwill
David Conwill's Avatar
Default 1952 Fordomatic rear-end ratio?
I'm corresponding with a seller about the '52 Ford passenger-car axle he has for sale. He says it's from an original automatic car - what was available with the auto? My books are all packed away, but I seem to recall 3.73 was standard with something higher as an option?
Thanks for any help.
1961 Falcon Futura
1962 Falcon Deluxe
Model T parts collector; gowjob aspirant.
David Conwill is offline   Reply With Quote
Old 06-18-2013, 11:01 AM   #2
charles in east texas
charles in east texas's Avatar
Default Re: 1952 Fordomatic rear-end ratio?
I think 3.73 is correct with automatic. 3.90 with standard and 4.11 with overdrive. Charles
charles in east texas is offline   Reply With Quote
Old 06-18-2013, 12:35 PM   #3
David Conwill
Thanks!
1961 Falcon Futura
1962 Falcon Deluxe
Old 06-18-2013, 12:36 PM   #4
Richardtx
The correct rear axle ratio for a Fordomatic Drive is 3:31. An optional ratio of 3:54 was available.
Richardtx is offline   Reply With Quote
Old 06-18-2013, 12:55 PM   #5
David Conwill
Well, that would be even better.
I wonder where I got 3.73?
Was there originally a tag with a code or some other way to tell without counting teeth or turns?
1961 Falcon Futura
1962 Falcon Deluxe
Old 06-18-2013, 01:16 PM   #6
Ol' Ron
Ol' Ron's Avatar
That's what mine is, too.
Old 06-18-2013, 05:07 PM   #7
Richardtx
The 3:73 ratio was used for standard transmission cars.
Old 06-18-2013, 05:36 PM   #8
Merc Cruzer
Merc Cruzer's Avatar
Just FYI: My 53' Merc-O-Matic is a 3:54...but it was the end of the run of flatheads so maybe that is all they had left.
Merc Cruzer is offline   Reply With Quote
Old 06-19-2013, 07:25 AM   #9
Buford
Buford's Avatar
My Fordomatic rear is 3:31 ...nice cruiser!
Support the effort to arm bears!
Preparation H will not stop asteroids!
Buford is offline   Reply With Quote
Old 06-19-2013, 07:49 AM   #10
51 MERC-CT
51 MERC-CT's Avatar
Not really because it was end of run but because the convertible and the wagon weighed more and both used the 3:54
Old 06-19-2013, 12:05 PM   #11
Merc Cruzer
Good to know
Old 10-24-2016, 06:16 PM   #12
alanwoodieman
just blew our rear axle in 52 with ford o matic. where do you find one to replace and what years fit?
alanwoodieman is offline   Reply With Quote
Old 10-24-2016, 07:47 PM   #13
scicala
scicala's Avatar
David,
You never said if you're '52 is a V8 or 6 cyl. I think they may have used different ratio's.
Sal
Old 10-24-2016, 08:10 PM   #14
paul2748
paul2748's Avatar
Any52-56 rear should fit. Always check length and spring pad width.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-24-2016, 09:10 PM   #15
alanwoodieman
found a Glenn Mitchell interchange manual (1961) that says Ford 52 to 54 and Merc 52-54 if you change out backing plates. V8 ratio 3:31
Old 10-24-2016, 10:01 PM   #16
Drbrown
Drbrown's Avatar
I believe Richardtx correct. Once researched and read that 3.31 was popular due to better pick-up, and that not many 6 cyl were sold with the matics due to lower power. Yet there's a few 6 owners out-there that love their cars.
There are a few matic owners that have/are converting to standard which is a significant undertaking. Maybe if you patient you'll get lucky and come across one.
Drbrown is offline   Reply With Quote
Old 10-24-2016, 10:06 PM   #17
Ol' Ron
Ol' Ron's Avatar
Have a 51 Merc o matic rear for sale, $150, new brakes and drums.
Old 10-25-2016, 08:11 AM   #18
donald1950
i ave a 1953 with fordomatic and the tag on the differential says 3.54
donald1950 is offline   Reply With Quote
Old 10-25-2016, 09:39 AM   #19
RalphG
RalphG's Avatar
3.31 is what all my books say for the 52 automatic equipped (Mercury). Seems to me mine has the number stamped into the axle housing. Thought I had a picture of it but can't find it now.
RalphG is offline   Reply With Quote
Old 10-25-2016, 08:21 PM   #20
Flatout
Flatout's Avatar
My 51 "Mercomatic" had a 3:07. That was in 1960. I can't say if it was factory installed or not. When I put a stick in it, it had to go. I had to downshift for every hill.
Flatout is offline   Reply With Quote
