Old 06-17-2013, 09:47 PM   #1
flatheadute1934
Default Miss over 40 mph
My uncle touring has a miss over 40 mph. He said if was only over 40 mph. Thoughts and suggestions. Stock 1930
flatheadute1934 is offline   Reply With Quote
Old 06-17-2013, 09:59 PM   #2
Doug in NJ
Doug in NJ's Avatar
Default Re: Miss over 40 mph
Getting too lean?
What happens if he opens the GAV?
Point bounce? (whatever that is...)
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 06-17-2013, 10:11 PM   #3
Gary WA
Gary WA's Avatar
Check point and rotor to cap gaps.
www.whidbeymodelaclub.com
Old 06-17-2013, 10:40 PM   #4
van Dyck
Point bounce = weak point arm spring. Actually the weak spring will not allow the points to close when the engine reaches a particular RPM. Also check to see if the point gap has increased.
van Dyck is offline   Reply With Quote
Old 06-17-2013, 10:52 PM   #5
Dave in Boise
Dave in Boise's Avatar
open the GAV a bit.. Easiest to try
Then I'd go with the ignition advice above (don't forget the condenser and coil as they will also exhibit some issues at higher rpms, especially as they get hot), a well as to check for good strong flow to the carburetor from the fuel tank..
Dave in Boise is offline   Reply With Quote
Old 06-17-2013, 11:12 PM   #6
Napa Skip
Napa Skip's Avatar
In no particular order:
1. Air/fuel mixture too lean:
a. Restricted fuel supply
(1) Plugged fuel filter (if installed)
(2) Gas cap not venting
(3) Plugged fuel tank outlet
(4) Carb float set too low
(5) Carb passage(s) restricted or plugged
b. Vacuum leak:
(1) Between carb and inlet manifold
(2) Between inlet manifold and block
2. Ignition:
a. Coil:
(1) Weak
(2) Polarity reversed
b. Distributor body:
(1) Rotor-to-body gap unequal
(2) Body cracked
c. Points:
(1) Not gapped correctly
(2) Corroded
(3) Spring weak or broken
d. Failed or weak condenser
e. Spark plugs:
(1) Incorrectly gapped
(2) Cracked insulator
(3) Fouled
(4) Wrong type or heat range
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
Old 06-18-2013, 03:26 AM   #7
johnbuckley
johnbuckley's Avatar
add to list : sloppy bushes in distributor.
Any more wanted?
johnbuckley is offline   Reply With Quote
Old 06-18-2013, 05:34 AM   #8
Patrick L.
Patrick L.'s Avatar
All good info. Could also be reversed coil polarity.
Old 06-18-2013, 11:07 AM   #9
Purdy Swoft
Purdy Swoft's Avatar
Check the spark plug wire strips on the distributor. Some spark plugs are shorter than others and need longer plug wires. if the wires are too short and contact the distributor cap , the number three wire can burn through the cap and cross fire to the number four wire inside the cap. I had this problem. My car would run ok at low speed but miss at highere rpm. I happened to be looking under the hood one night with the engine running and saw the sparks flying between the edge of the cap body and the number 3 plug wire strip when I reved the engine. Check the distributor cap body for melted spots under where the wire is contacting the cap. this usually only happens if the plug wires are too short and touching the cap body. Just a thought.
