Old 06-14-2013, 02:09 AM   #1
Doot
Doot's Avatar
Default Timing?????!!!!!
I did it exactly the way the book says.... 3 times!
I used the little pin in front on main crank.
Lined it up
Turned rotor cam to line up on no.1 in distributer.
Turned it 180 degrees opposite like it says...
Set the points and rotor cam to the exact specs from the book...
Put it all back together...
Cranked her over.... Spit ... Sputter... No fire!
A couple of exhaust fume smoke... That's it!
What the f*ck is my solution?
Thank you to all involved!
Doot is offline   Reply With Quote
Old 06-14-2013, 02:32 AM   #2
christian
christian's Avatar
Default Re: Timing?????!!!!!
Once you are in TDC, loosen the rotor cam locking screw, rotate it a few times clockwise to remove backlash, then stop it just as the points close with the rotor pointing to the #1 distributor contact. If you did it correctly, the slightest movement counter clockwise should open the points.
Not really sure what you mean about rotating 180 degrees..........
1931 Slant Windshield fordor
christian is offline   Reply With Quote
Old 06-14-2013, 02:33 AM   #3
christian
christian's Avatar
Also, make us you set the points gap before you do the timing. As changing the points gap will effect your timing after the fact.
Old 06-14-2013, 02:39 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
There are a bunch of ways to to this.
This method http://www.abarnyard.com/workshop/timing.htm not only explains the method but also the reason for the steps.
Questions, was that coil you spoke about earlier; new or used, 12 volt or 6 volt? An incorrect or weak coil can also give those symptons.
Old 06-14-2013, 04:13 AM   #5
James Rogers
James Rogers's Avatar
The easiest way is to:
1 Line up the cam timing gear with the pin by rotating the engine till the pin drops into the dimple.
2 Loosen the screw in the distributor cam and rotate the cam Counter-clockwise till the notch is in the general direction of the right headlight and the cam just touches the bumper on the points. Lock the cam with the screw.
3 Assemble the distributor and start the engine.
Make sure you set the points and have the lever in the full retard position before beginning this sequence.
I don't understand where you need to rotate the cam 180 degrees after locating #1. This would time the engine 180 degrees out of time and is most likely your problem.
Old 06-14-2013, 04:49 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Poor choice of words in the manual, but OPPOSITE means NEXT TO, so you did good right up to the point where you moved it 180*
Old 06-14-2013, 05:26 AM   #7
Wick
Wick's Avatar
If it spits,then just turn the rotor (pointed at #1) counterclock wise a 1/8" at a time untill she starts. After it starts,if you pull the spark lever all the way down and drive it....try and wind out second gear,it it doeset pull hard and it spits a little and seems to run hot,Then turn the rotor counterclock wise again. Do this untill she acts right. I know this is not the proper way to set the timing,but if your old school and did v-8s this way (I Did not own a timming light) it might make scense. This works great on VW-Bugs!
Wick is offline   Reply With Quote
Old 06-14-2013, 05:32 AM   #8
Patrick L.
Patrick L.'s Avatar
I'm wondering if you are using a Model B timing cover, they are about 19º different.
Old 06-14-2013, 07:34 AM   #9
Banky
LISTEN TO TOM! I did the same exact thing.
Banky is offline   Reply With Quote
Old 06-14-2013, 08:59 AM   #10
John LaVoy
John LaVoy's Avatar
I was thinking Model B also.
John LaVoy is offline   Reply With Quote
Old 06-14-2013, 10:49 AM   #11
zzlegend
zzlegend's Avatar
Tom has it right. That can be mis leading when it states, point the rotor opposite of number one.
zzlegend is offline   Reply With Quote
Old 06-14-2013, 10:59 AM   #12
1931 flamingo
1931 flamingo's Avatar
When you replaced the timing gear did you get the dots lined up correctly?? When setting the timing and then when you're trying to start it do you have the spark advance lever in the UP position??
Paul in CT
Old 06-14-2013, 11:32 AM   #13
Purdy Swoft
Purdy Swoft's Avatar
Most of the timing instructions that I've seen in the how to books can be confusing to the newby model A owner. Some are confusing by a poor choice of words, others by adding tests that only add more confusion. A lot of problems are caused by the backlash in the distributor shaft (free movement in the dist. shaft).. Here is how I set mine. I first remove all of the spark plugs. There is NO need in fighting compression when tring to set the points or finding the dimple in the timing gear with the timing pin. I then set the points at .022 .. When the timing dimple is found with the timing pin, I loosen the points cam screw and set the rotor so that the trailing edge of the rotor tip is pointing at the number one contact in the distributor cap body. The distributor turns counter clockwise when the engine is running and the trailing edge of the rotor tip will be the rear edge when the rotor is turning counter clockwise, as when it is running. The number one contact in the cap body is the right front when standing on the passenger side. There will sometimes be 1/2 inch or more free movement or backlash in the distributor shaft. Counter clockwise backlash doesn't effect the timing. With The timing pin in the dimple of the cam gear, tighten the points cam so that the trailing edge of the rotor tip is pointing at the number one contact in the distributor cap with no clockwise backlash. In other words let the backlash ALL be in the counter clockwise direction when the points cam screw is tightened. It may take several tries because the points cam will try to turn as you tighten the screw. If clockwise rotation or backlash remains, the timing will be retarded the amount of the clock wise backlash that remains when the cam screw is tightened . To test, retard the spark lever, the points should be just about to open. With a screw driver that just fits the cam screw , back the screw up to the end of the clockwise backlash. With the ignition switch on, the slightest movement of the cam screw in the counter clockwise direction will open the points and you will hear an electrical pop and a spark at the points. I skip the test because if the trailing edge of the rotor tip is pointing in the correct spot with no clockwise backlash, the timing will be right on. I have years of experience setting model A timing. Some need to test with a screwdriver, I find that this confuses most to the point that they are unable to get the timing correct.
Old 06-14-2013, 05:21 PM   #14
William Kelchner
William Kelchner's Avatar
For some reason I could never get the timing right on my 30. I followed Purdy Swoft's method. The beast has been running great ever since.
William Kelchner is offline   Reply With Quote
Old 06-14-2013, 05:34 PM   #15
700rpm
700rpm's Avatar
I made a simple test light with a 6V bulb and alligator clips. Otherwise using Purdy's method for removing backlash, the bulb tells me exactly when the points open.
Ray Horton, Portland, OR
Old 06-14-2013, 11:42 PM   #16
acurbhopper 2
I think you are reading opposite as 180 degrees from no.1, but what it means is just before no. 1 in direction of rotation.
acurbhopper 2 is offline   Reply With Quote
Old 06-15-2013, 11:10 AM   #17
Tugmaster
There is actually a YouTube video on how to time you car. Look up "how to time a Model A"
Hope this helps.
Tugmaster is offline   Reply With Quote
Old 06-15-2013, 12:00 PM   #18
amdriven2liv
amdriven2liv's Avatar
Here is the video I watched:
https://www.youtube.com/watch?v=mwirH7f0a9o
We Walk for Kay
1928 Model A "Special" Coupe.
amdriven2liv is offline   Reply With Quote
Old 06-15-2013, 01:38 PM   #19
msmaron
msmaron's Avatar
Have you made sure your carb is NOT Clogged, fuel is flowing, air/gas mix set correctly...??
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-16-2013, 01:16 PM   #20
Doot
Doot's Avatar
Okay....read all of your comments! I liked them all! I have to agree about the "opposite" wording problem....I will do the timing again, only this time, I won't turn the rotor "opposite" of the number one pin in the cap! Then I will get back to you.... I have a really bad cold, so it won't be for another day or two! Thank you all!
