Old 05-29-2013, 12:48 PM   #1
Uncle Bob
Uncle Bob's Avatar
Default 600w............enough is enough!
I wish.........
Hardly a week goes by that we don’t have at least one thread inquiring about 600w lubricant in some form or other. The variety of responses, while well intentioned, are usually not very clear because of a mix of often repeated misinformation, and some fact or sufficiently close to fact. Many attempts by several on these boards to give accurate info are often overwhelmed by a variety distractions particularly injecting the use of “magic in a bottle” additives, but not restricted to that. So, here’s my attempt to help by sharing a couple of legitimate standards in the lubrication industry that SHOULD (but, sadly, likely won’t) set an accurate baseline.
The first is something called a Data Sheet. These are publications by the lubricant producers that spell out technical data as well as typical application information. In this particular case, 600w (or more completely, 600w Steam Cylinder Lubricant) is a trade name owned by Mobil Oil, today known as Exxon Mobil Corp. This product (in evolving formulations) has been in existence for over 100 years, thus it’s reference as a lubricant for vehicles 80 years old. For those interested you can make a copy of Mobil’s data sheet here: http://catalog.mooreballiewoil.com/Asset/pds-76.pdf Just right click with your mouse on the document and click “print”. The data sheet gives all manner of information (too much some would say), but it clearly answers the frequently asked question regarding viscosity grade. This particular product is what’s known as an industrial oil, as opposed, for example, to an automotive oil. As such they use a different nomenclature for viscosity grade (think of it as a different language wherein there are different appearing terms that mean the same thing or close depending on context). This particular product is especially confusing for the partially informed because of the 600, and especially, the “w”. When automotive guys see a number value in the nomenclature they immediately think “viscosity”. However, in this case, that 600 doesn’t equate to any currently used viscosity nomenclature. Then there’s the “w”……………………………WARNING; RANT WITHIN A RANT……….Real lubrication authorities will NEVER use the term “weight” in reference to viscosity grade………….NEVER (well, unless they stoop to pandering to improper colloquialism for the sake of communication). You’ll never see the term “weight” on an official oil company data sheet in reference to viscosity. When you see a “w” in any product name or viscosity designation it means something else……………..NOT weight. (Any of you familiar with concrete products will recognize a similar reaction when the ill informed refer to concrete as cement……..or in your area of expertise something similar).
Which brings us to the second reference document. Go to the picture below, click on it to enlarge, it is a Viscosity Equivalent Chart. This is useful in comparing the different “languages” of viscosity grading where in you can see the equivalent viscosity grade of an automotive gear lube (for example) when compared to an industrial viscosity grade. So, to work from the 600w data sheet, it self identifies as an ISO 460 grade, which lines up with an SAE 140 gear lube. Now, some confusion may occur to the observant. An ISO 680 (more viscous than an ISO 460) also translates to an SAE gear lube 140. This occurs because the SAE gear lube specification encompasses a wider range of viscosity measurement than each of the ISO grades. Think of it as an ISO 460 is a “light” 140, and an ISO 680 is a “heavy” 140 (this is me pandering to colloquialism). So, which is “right”. Technically they both are, but that’s where operating conditions form the context. Those that believe “more is better” will go to the high end. Those that are aware of operating conditions might correctly understand that, as an example, in a cooler climate the more viscous product will cause unnecessary fluid friction and reduced lubrication performance.
So, does using the term “600w” mean that only the Mobil product would be correct for the stated application. No, not really. With accurate understanding of lubricant data there are alternate cross references. Most industrial oil producer/marketers have a “steam cylinder” oil, probably very similar to the Mobil formulation. And as some have learned empirically, there are other brand/types of lubes that perform in automotive applications just as well. Which is not to say that ONLY comparing viscosity grades is adequate to determine a suitable substitute. There are other considerations, most notably additive chemistry, but again, the data sheet will often be your best friend there in conjunction with a little education.
This posting isn’t intended to be all encompassing, as stated in the first paragraph it sets a baseline of accuracy from which to expand if necessary. At which point I will bite my cynical tongue and not say what I’m thinking about that.
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 05-29-2013, 01:14 PM   #2
Dave in Boise
Dave in Boise's Avatar
Default Re: 600w............enough is enough!
well written.. thank you very much!
- Dave in Boise
Dave in Boise is offline   Reply With Quote
Old 05-29-2013, 01:17 PM   #3
Purdy Swoft
Purdy Swoft's Avatar
People go to great expense and trouble trying to find the perfect gear lube. A few weeks ago somebody from Snyders said that they sold 140 and that Bratton sold the same because they sold it to them. That said why pay shipping from a model A vendor or buy five gallon quanities when 140 can usually be purchased locally and works as well as any other. I used 90 weight gear oil in the sixties and seventies and i'm not so sure that it didn't work better.
Old 05-29-2013, 04:37 PM   #4
marc hildebrant
marc hildebrant's Avatar
Uncle Bob,
So.....what do you run in your Model A transmission ?
Marc
marc hildebrant is offline   Reply With Quote
Old 05-29-2013, 04:43 PM   #5
Terry, NJ
Terry, NJ's Avatar
One of the problems as I see it, Is the newbies (Me for one) tend to look upon our vintage iron as a real and precious antique that must be pampered. Hell when these cars were new, no one thought they were anything but cheap and fairly reliable transportation. Not to mention the lack of finances during the depression and the rationing of oil during the war. Maintenance was sketchy at best in most cases. But now they're old and venerable. It's only natural that we'd want the best of care for them. Not being around in 1930 it's hard to keep it in mind that the worst of today's lubricants is better then the best of the 20s and 30s and 40s. And we want to believe! Many of us are suckers for anything "new and Improved" and with today's improvements in oil technology, we can get "Magic in a bottle". Of course it's rarely as "magical" as the advertising would have us believe. Steam Cylinder Oil? what's that about? Sounds like something they used on the Mississippi steam boats of a century ago! 600W ? It's got to be more like peanut butter, than oil! Surely one of the "Magical" concoctions has got to be better. So we ask, and ask, and ask! Not realizing that we could probably just throw the junk that our grandfathers threw in there and it would be fine!
Terry
Terry, NJ is offline   Reply With Quote
Old 05-29-2013, 04:54 PM   #6
marc hildebrant
In Longmont/Colorado they have an old time farm equipment show every year. The person running the Steam Tractor (burned wood) told me that he used Steam Cylinder Oil to lubricate the cylinders. I saw the oil and it was thick on a hot Colorado day.
Very large machine too!
Marc
Old 05-29-2013, 04:59 PM   #7
Kevin in NJ
Some of the other considerations that are dear Uncle was talking about.
For example there are some oils made for gears that have a shearing action like most modern cars. Steam cylinder oils are designed for high pressure applications like straight cut gears. Keep in mind that the A is all straight cut gears that need a sticky oil that does not squish out easy.
Notice that many of the axle tubes do not have a rust problems and you have to work at cleaning the oils from the inside of the tubes. This is an important property to prevent the daily condensate some areas will get from causing rust on the parts. The original type oils just kind of get around and stick forever coating the housing.
It is interesting that the 'correct' 680 series oil has the same smell as the original type oil drained out of the rear and tranny. I know this sounds strange, but there are things you notice. Just like most of use wonder what happened to the gas smell when we put gas in our cars, the new stuff just does not smell right.
Kevin in NJ is offline   Reply With Quote
Old 05-29-2013, 05:08 PM   #8
Patrick L.
Patrick L.'s Avatar
It looks to me from the chart that ISO 680 is 190 wgt and ISO 460 is 140 wgt. [or should I say viscosity]. I've used 140 and 250 and really don't see much difference between the 2. I've also used 90 and prefer the heavier, but, I believe any would be fine. The only oil I couldn't use was the Lucas, it turned to foam and became un-shiftable.
Old 05-29-2013, 05:17 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Wait two weeks and the question will be back. It is just the way it is!
Old 05-29-2013, 05:18 PM   #10
Uncle Bob
Uncle Bob's Avatar
Originally Posted by marc hildebrant View Post
Uncle Bob,
Marc
As a matter of convenience I use readily available 85w/140 gear lube, usually Chevron. Technically it's way overkill performance wise, but it's the recommended viscosity range and available in handy quarts. Some worry about the EP additive (sulfur-phosphorus compound), but there's little yellow metal in Model A gear boxes, and the EP isn't very reactive at the typical temps we see. EDIT: there are any number of other lubricants I would use were it not for the convenience factor. Most of the reasonable alternatives are not typically packaged in small usage containers nor readily available in standard retail venues.
Terry, I'm not sure where you would get a "peanut butter" consistency analogy from the data I presented. Perhaps it's your attempt at humor? Viscosity is measured in relatively sophisticated equipment to procedures tightly controlled for repeatability. No comparison to the results from a calibrated eyeball. As for "why a steam cylinder oil?"; the observation that lubricant technology was in it's infancy in the day is appropriate. Steam cylinder oils developed in the 19th century (such as 600w) used what was known at the time. In that case, the "w" likely represented whale oil, which over 100 years ago was learned to have natural adhesion in wet environments. We've learned in the progress of discovery that the molecular structure of whale oil contained polar molecules that would adhere in wet environs (similar to a magnet adhering to steel/iron). This enhanced the lubrication process. I would suppose that the Ford designer/engineers used a technology they believed would benefit the application and the polar nature of a steam cylinder oil would give added protection. Since the ban on whale oil other organic compounds were developed that had similar physical, polar, properties as a replacement.
Gear oils, industrial oils, motor oils, almost all compounded lubricants contain rust and oxidation inhibitors. Oils without at least those two additives are not readily available to the general consumer unless you're talking about straight mineral oils (often food grade) or small machinery oil e.g. sewing machine lube.
Old 05-29-2013, 06:10 PM   #11
Uncle Bob
Uncle Bob's Avatar
LOL.........I doubt it will take that long Mike.....
Old 05-29-2013, 06:14 PM   #12
mrtexas
mrtexas's Avatar
Here is my 2ct worth. I bought 5 gallons of both 460 and 680 steam cylinder oil. A local Model A supplier sold what I didn't use.
680 will work in warm weather and make shifting a breeze, double clutching hardly needed. Forget about it in the cool weather we get in Texas in winter, shifting is difficult. With real cold weather 680 freezes up and you won't be able to shift at all. Use 460 in cold weather. Or better yet, use a more modern oil. Steam cylinder oil is very old fashioned!
mrtexas is offline   Reply With Quote
Old 05-29-2013, 06:23 PM   #13
mrtexas
mrtexas's Avatar
I scheduled production of lube oils at a large Gulf Coast refinery for a couple years as a Chemical Engineer.
Another bit of trivia. Viscosity is a measure of a liquid's resistance to flow. The unit of measure are cSt or SUS. For lube oils in the metric system, the temperature of measurement is 40C(104F) and 100C(212F).
The primary measurement of lube oil quality, viscosity index, has to do with how the viscosity changes between 40C and 100C. The best lubricants change the least in viscosity with temperature. You don't want your lube oil to thin too much at high temperatures or stiffen up too much at low temperatures.
cSt stands for centi-Stokes and is a metric system unit
SUS stands for Saybolt Universal Seconds Viscosity can be measured by filling up a standard sized tube with a measured hole in the bottom of it at a specific temperature. SUS is the number of seconds it takes to empty the tube.
Old 05-29-2013, 07:31 PM   #14
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The Dog says,
When someone asks about gear oils in the future, just DON'T answer them!! Then, maybe, they'll learn to use the "SEARCH" feature & amuse themselves for HOURS!! Same for motor oil questions. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-29-2013, 08:16 PM   #15
1931 flamingo
1931 flamingo's Avatar
I don't know, it just amazes (bothers) me that everyone wants to re-invent the wheel. Reliable suppliers to this hobby have gone out and given us 600W (I don't care about it's chemical make up, viscosity, characteristics, etc) in a convenient, easy to use bottle that's relatively inexpensive. Use it. MOST of us probably don't drive more than 1000-2000 miles a year. If you'd changed and put "some kind" of fresh gear oil in your trans and rear end, the lubricating qualities are going to outlast probably all of us. Sorry for the rant. As Bill says the "search" function is a valuable resource.
Paul in CT
Old 05-29-2013, 08:20 PM   #16
ctlikon0712
ctlikon0712's Avatar
Uncle Bob and mrtexas, thank you. I really got allot out of this.
I makes me think of the wildling girl in Game of Thrones.
"You know nothing John Snow!"
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 05-29-2013, 08:21 PM   #17
Mitch//pa
Paul in CT
i agree and could also care less about the mumbo jumbo that gets dug up on this topic .. enough is enough
Old 05-29-2013, 08:33 PM   #18
Dusty
Dusty's Avatar
OK, let me get this straight, 600W does not mean 600 weight
Lookin for the drain plug on my transmisson in WV
dusty
Dusty is offline   Reply With Quote
Old 05-29-2013, 08:40 PM   #19
Purdy Swoft
No real problem here . 600W and oil threads just give us a chance to discuss it again, many still don't know the facts.
Old 05-29-2013, 09:19 PM   #20
redmodelt
redmodelt's Avatar
I was told the W was there because it was sold by weight not volume. So instead of buying a pint you bought a pound.
