Old 05-19-2013, 09:29 PM   #1
Doug in NJ
Doug in NJ's Avatar
Default Brake lining dimensions?
Hello,
I have a set of brake linings that may or may not be for an A. Does anyone happen to know the correct length and width of an 'A' brake lining?
Thanks,
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 05-19-2013, 09:39 PM   #2
QGolden
QGolden's Avatar
Default Re: Brake lining dimensions?
My new front liners are 1 1/2 wide, 14 1/8 long. 10 1/2 straight across the shoe when installed.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 05-19-2013, 10:06 PM   #3
Doug in NJ
Doug in NJ's Avatar
Thanks for the info. The ones I have are 1-1/2" x 15-3/4". :-(
Doug
Old 05-20-2013, 05:45 AM   #4
QGolden
QGolden's Avatar
If they are not Pre-drilled you could probably drill them, mount them to the shoes and grind the extra off?
Old 05-20-2013, 03:28 PM   #5
ctlikon0712
ctlikon0712's Avatar
Here is a photo of an old set of liners with their factory part # and dimensions.
I do have a related question. The third pic shows Comax liners made by Wagner, and the label states 4 liners low friction, 4 liners standard friction. How was that supposed to be configured? Low in the rear and standard in the front? Since by the 50's, drivers were accustomed to a front biased braking system.....?
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 05-21-2013, 12:28 AM   #6
ctlikon0712
Btt.
Old 05-21-2013, 02:09 PM   #7
Jim Parker Toronto
Jim Parker Toronto's Avatar
The linings you have could be off a Model B. They went from an 11" brake drum to a 12" drum. These are diameter readings, so you can do the math.....
Jim Parker Toronto is offline   Reply With Quote
