Old 05-09-2013, 05:34 PM   #1
msmaron
msmaron's Avatar
Default Timing on Model A w/B Distrib....UPDATE & REPAIR!!!
Any help is appreciated. Have a B Cover on my Model A Engine and just in stalled a newly restored B Distributor.
Set Point gap at .20, found BTDC with timing pin in B Hole. set cam timing with a light to get it perfect. Have a original pop out switch modified with the quick connect wire to a armored cable to B distributor, new points, new condenser. New distributor body and cap, extended copper straps from the spark plug to the distrib for good solid connection.
Getting great spark at points, getting spark from coil wire to head nut making the gap, fuel fine, elec fine and full 6 volts, all accessories working fine also.
CANNOT get it to start at all. Turns over fine but wont catch at all. Fuel flow is fine just will NOT Catch and start..
ANY Help would be appreciated.
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 05-09-2013, 05:39 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Please help with Timing on Model A w/B Distrib....problems!!
Rotor?? Is the dist turning?? Even if the body is new do you have continuity thru it??
What if we bypass the pop out by jumping across the junction box?? I'm trying to be helpful and I know you've got good experience but these are the things that popped into my head. Good luck and keep us posted, please.
Paul in CT
Old 05-09-2013, 05:46 PM   #3
msmaron
msmaron's Avatar
Hmmmm rotor, well never considered that as it was the same rotor this AM that i used on the A Distrib..but i can try it..why would you suggest bypassing the junctin box???
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-09-2013, 06:13 PM   #4
msmaron
msmaron's Avatar
Yes paul the rotor is fine...spinning and spark from the plugs also
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-09-2013, 06:25 PM   #5
1931 flamingo
By jumping at the junction box do you not bypass the pop out or is that only with a replacement cable?
Now you say you even have spark at the plugs and it still won't fire?? No pops, nothing?
If it wasn't for the pop out Id ask if the key was on? Are A&B rotors the same?
Paul
There are 2 threads open, same title and both being answered to.
Old 05-09-2013, 06:27 PM   #6
msmaron
msmaron's Avatar
yes and a & bo rotars are the same, and yes i get pops and it wants to catch but wont..
the pop out is only the switch part...the cable has been removed.
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-09-2013, 08:06 PM   #7
Purdy Swoft
Purdy Swoft's Avatar
If it pops but won't start, the timing is set wrong. it may be one of two causes. If you have the correct B timing cover, you should be able to set the timing with the timing pin. You say that you used a timing light to get the timing perfect, it must not be. Try setting the timing with the pin and forget the timing light. Another possibility is that you have a service replacement model A timing cover instead of an actual B cover. Both the service replacement A cover and the B cover have the raised oval boss where the pin installs. The real B cover has the threaded hole for the pin at the top of the raised boss. If you accidently used the A service replacement cover the timing will probably be 19 degrees off.
Old 05-09-2013, 08:32 PM   #8
ursus
As noted above by Purdy Swoft, make sure you have a B cover. Easiest way to check: the timing pin drilling on the B cover is closer to the perimeter bolt hole above it, and on the A cover it is closer to the hole below the drilling.
ursus is offline   Reply With Quote
Old 05-09-2013, 08:42 PM   #9
Purdy Swoft
After the B engines, were introduced, rather than make two different covers for an A replacement, both covers had a raised oval boss. The model A service replacement cover had the hole for the timing pin drilled at the lower end of the raised boss. The actual B cover had the hole for the timing pin drilled at the upper end of the raised oval boss.
Old 05-09-2013, 08:56 PM   #10
msmaron
msmaron's Avatar
YES I have the cover with the raised boss and the hold drill and tapped for the B at the raised part of the boss and also for the A under it.
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-09-2013, 09:24 PM   #11
J Franklin
J Franklin's Avatar
How is the compression?
Old 05-09-2013, 09:27 PM   #12
msmaron
msmaron's Avatar
Yes all is fine. Car was running perfect with the A dist
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-10-2013, 02:11 AM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
When the timing pin drops into the detent in the cam gear, is the rotor pointing towards the right headlamp?
It should be, and the points should just be ready to break open with the rotor turning CCW.
Old 05-10-2013, 04:04 AM   #14
msmaron
msmaron's Avatar
Yes that is correct Tom
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-10-2013, 05:13 AM   #15
James Rogers
James Rogers's Avatar
Sounds like fuel problems. You need three things at the correct time, fire- check compression- check fuel-?. Check the carb.
Old 05-10-2013, 06:12 AM   #16
[email protected]
modela@aol.com's Avatar
Mark,
Now grasping at straws..... You said this is your new Model B dist, so do you have another B condenser to swap out just in case. You said you are getting spark but a different condenser could give you a better spark.
modela@aol.com is offline   Reply With Quote
Old 05-10-2013, 08:45 AM   #17
msmaron
msmaron's Avatar
The carb is fine. Car ran perfect on the am. Compression is fine also.
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-10-2013, 08:45 AM   #18
msmaron
msmaron's Avatar
Originally Posted by [email protected] View Post
Mark,
Did just that put in a new condenser
Thanks
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 05-10-2013, 09:55 AM   #19
Wick
Wick's Avatar
Forget about the timing pin for now.
Put the A dizzy back in and get it running. cut the motor off and turn it over to where #1 fires. Lift the A dizzy out and set the B dizzy in...now set rotor to where #1 fires it should start.
Wick is offline   Reply With Quote
Old 05-10-2013, 10:04 AM   #20
Hasler55
Hasler55's Avatar
If you have great spark recheck the timing. Do it the old fashioned way by checking to see if the rotor aligns with the first cylinder point at tdc.
Hasler55 is offline   Reply With Quote
