Old 05-05-2013, 08:41 PM   #1
marks1929tudor
Angry Help with speedo cable
Need help with my speedo cable , they keep breaking on me!!! The original cable broke twisted off about 3 inches from trans end , figured lack of lubrication car had sat for a few years, replaced with brand new cable inside and out drove couple miles and that one twisted off about three inches from trans end. Bought new cable( had to buy complete cable in and out . Took trans end apart cleaned and greased , oiled it all up and put back together. Removed speedo and oiled with fine oil used old end in a drill to spin ( worked really easy and well ) reinstalled new inner cable in the first speedo cables new outer and drove about five miles and this one broke, did not take apart yet but I'm at the end of my wits with this speedo lol . Any help or advise ? Cable was lightly lubricated in the metal outer not sure what I am missing or what is causing these to break HELP !!!!!!!!!
marks1929tudor is offline   Reply With Quote
Old 05-05-2013, 08:46 PM   #2
spdway1
spdway1's Avatar
Default Re: Help with speedo cable
It might be a sign of the Speedometer starting to go bad as mine did a few weeks back, I put a new cable in last summer, another new cable and speedometer last week after it seized up.
spdway1 is offline   Reply With Quote
Old 05-05-2013, 08:55 PM   #3
Mitch//pa
I would say you have a problem in the speedo head. The inner cable usually breaks at the opposite end from where the seizure is as the cable is able to be wound from the seized point and breaks off at the end that is still rotating ..
Old 05-05-2013, 08:59 PM   #4
lindy williams
Remove speedo cable from speedo and with your thumb and forefinger, try to spin the speedo shaft. It should spin easily. If it is hard to turn or if you can't turn it at all with your fingers, the speedo needs to be lubricated, particularly the vertical shaft in the speedo.
lindy williams is offline   Reply With Quote
Old 05-05-2013, 09:23 PM   #5
marks1929tudor
That's what baffles me as I used the end of the broken cable and put it in my drill speedo spins freely no problems , I even tested a couple of other speedo I have laying around and feels the same !!!
Old 05-05-2013, 09:24 PM   #6
marks1929tudor
Does anyone sell just the inners I am getting a collection of outers that are doing me no good!!!
Old 05-05-2013, 10:03 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Also make sure the cable is mounted well above the hot muffler, and make sure it has no sharp bends.
Old 05-05-2013, 11:02 PM   #8
sethkestenbaum
sethkestenbaum's Avatar
I had the same problem. The speedo should turn with you little finger and with little effort or pressure. Before I cleaned mine out, it would turn (with no problem if I used a drill), but there was a little resistance occasionally if I used my fingers. To fix mine, I popped the bottom off of my speedo, cleaned out the grease, filled and emptied it with PB Blaster several times (to break up any gunk) and then filled with new grease. It has worked ever since. Here is a link to the thread:
https://fordbarn.com/forum/showthread.php?t=53013
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 05-05-2013, 11:40 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Snyders sells them,
http://www.snydersantiqueauto.com/3137
