Old 05-01-2013, 04:45 PM   #1
George D
George D's Avatar
Default Oil pan paint
Just bead blasted 29 oil pan, Henry painted the inside I think. Should it be? And if so, with what? I know that the oil should protect it from rust but it doesn't appear to have done so. What do you guys do? Thanks
George D is offline   Reply With Quote
Old 05-01-2013, 04:50 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Oil pan paint
Bare metal. You could treat it with a Phosphoric acid etch, as it leaves a rust resistant finish that will resist rust and never peel.
Russ/40 is offline   Reply With Quote
Old 05-01-2013, 04:54 PM   #3
George D
George D's Avatar
Ok thanks
Old 05-01-2013, 07:46 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I paint the inside of the pan and the dipper tray with DP-90 primer and DCC 9000 top coat. And I don't fear it coming off.
