08-11-2010, 01:19 PM | #1 |
Leaning to the left.
I have a 31 fourdor and I have notice that the left side of the car is down about 1 1/2 inches front and back. The axels are level but the frame is down. I don’t have rear shocks but I do have front ones. Any idea where I should start to check? The frame blocks seem to be installed and look good.
Ron |
08-11-2010, 02:01 PM | #2 |
Re: Leaning to the left.
first try bouncing up & down on the passenger side running board . you cant get some movement that way . i loosen my spring hanger "U" bolts (frame to spring) , then bounce it . it will let the spring move a little to the side . this should help some . mine was like that due to only having a person driving , no passenger . the spring will either sag or shift . you can also reverse thew spring . take it out & swap ends . if you take it out , be very carefull on how you do it . it will take your head off . use a spring spreader & be very careful . good luck .................... steve
V4f |
08-11-2010, 02:37 PM | #3 |
Just get a gal thats heavier than you to ride along!
08-11-2010, 04:26 PM | #4 |
Leaning to the left. Put some weight on the right!
I knew this thread was going to go in this direction...Good humor!
Thanks! Dave in MN PS: I had almost the same cure for my car! The center bolt had snapped and the springs were shifting. Replacing the bolt and re-centering fixed the problem. |
08-11-2010, 04:53 PM | #5 |
for a temp fix, when you get out of the car [driver's side] push up on top of the door jam, it will level it out untill you get in it agin, only takes a split second.
most "A's" i,ve been around do lean to the left. |
08-11-2010, 08:36 PM | #6 |
08-11-2010, 08:54 PM | #7 |
As with Art, replacing the rear spring brought it back to level. Unfortunately, I replaced the front spring thinking it was down on the front corner. After measuring the whole side I realized the fatigued rear spring being much larger controlled the whole side.
08-12-2010, 01:39 AM | #8 |
First try loosening and retightening the 4 nuts holding the rear spring in place. My 29 Tudor leaned to the left until I R & R the rear end to replace the clutch disc. Now it sets perfectly level.
08-12-2010, 06:42 AM | #9 |
Thanks for everyone's help. I will try some of your suggestions except the one "have a gal that's heavier than you to ride along!" HA,ha
Ron |
08-12-2010, 10:26 AM | #10 |
The other idea is to move the car to England or Down Under where they all lean to the right. Yours would be unusual there.
I have the same problem and always look at the "Spring Guy's" booth at the Hershey show. |
08-12-2010, 10:30 AM | #11 |
Unbolt rear spring, rotate 180 degrees and re- install. Now its right, when you sit in the car it will be level. Just a thought.
08-12-2010, 11:54 AM | #12 | |
08-12-2010, 10:13 PM | #13 |
"Just get a gal thats heavier than you to ride along!"
I can't afford to feed a gal that big. |
