Old 04-26-2013, 07:34 AM   #1
lookin-backtexas
lookin-backtexas's Avatar
Default Win a freshly rebuilt Model A engine with insert bearings
The Lone Star Model A Ford Club of Georgetown, Texas is hosting the 50th Model A Ford Texas Tour (statewide convention) June 6 - 9 and is having a raffle to win a freshly rebuilt Model A engine built by Taylor Made Motors of New Braunfels, TX. The engine is valued at $5,000 and raffle tickets are just $5 each or 5 for $20!
Engine specs include:
Block cleaned and checked for cracks
One piece main bearings
One piece rod bearings
New tri-metal connecting rods
Counter balanced crankshaft
Pressurized center main
New aluminum timing gear
New crank gear
Rebuilt oil pump
Reground touring camshaft
Modern stainless steel valves (1.73 intake / 1.53 exhaust)
New exhaust manifold gaskets
New intake manifold gasket
One piece valve guide
Modern valve keepers
New valve springs
Motor balanced
Block tapped for modern main bolts
Porting on the valve ports
New oil pan bolts
New valve cover bolts
New front pulley
New head gasket
Grade eight head studs and nuts
Cut down (lightened) flywheel
New clutch disc
New pressure plate
New pilot bearing
Modern front seal
Motor completely assembled
Engine painted Ford engine green
Oil pan cleaned and painted black
Snyder 5.5:1 High Compression Head
Heater/exhaust manifold
Intake manifold painted to match engine
Test run to verify performance
Total value as built: $5,000
Carburetor, distributor, starter and water pump not included
The drawing will occur June 8, 2013 during the 50th Anniversary Texas Tour Awards Banquet held at the Marriott Hotel, Round Rock, TX.
Winner need not be present to win but must claim prize on or before July 1, 2013.
Raffle tickets available for $5 each or 5 for $20
Make checks payable to "50th Texas Tour" and mail to:
3404 Indian Mound Road
Georgetown, TX 78628
Be sure to include your email address so we can confirm receipt of your entry and your telephone number so we can notify you if you win!
Fred Carlton
Life Member AACA
44 year member MAFCA
Editor of The Restorer magazine, official publication of MAFCA 12 years
Life Member Dallas Model A Ford Club (44 years)
23 year member & founder Lone Star Model A Ford Club
Chairman 35th Model A Ford Texas Tour 1998 (state convention)
Chairman 42nd Model A Ford Texas Tour 2005 (state convention)
Charter Member Ford Model AA Truck Club
If you aren't driving your antique car frequently, you might as well be collecting clocks!!!
lookin-backtexas is offline   Reply With Quote
Old 04-26-2013, 08:47 AM   #2
luckyal
Default Re: Win a freshly rebuilt Model A engine with insert bearings
I indeed wish you well but I wonder why you would not include the carburetor, distributor and waterpump ? Curious !
Al
luckyal is offline   Reply With Quote
Old 04-26-2013, 08:49 AM   #3
Jordan
Jordan's Avatar
Who built the engine? already bought my tickets
Cowtown A's
Jordan is offline   Reply With Quote
Old 04-26-2013, 08:52 AM   #4
lookin-backtexas
Jordan:
The first paragraph of the original listing states that the engine was rebuilt by Taylor Made Motors, New Braunfels, TX.
Good luck with the raffle and thanks for buying a ticket!
Fred
Fred Carlton
Life Member AACA
Old 04-26-2013, 08:55 AM   #5
lookin-backtexas
Al
Al: With a user name like "lucky al" you surely should buy a raffle ticket! ha
Can't really answer your question - our tour chairman made the arrangements with Taylor Made Motors to rebuild the engine so don't know why it doesn't come with the distributor, carb, water pump or starter.
Even without those items the retail value of the balanced inserted main bearing engine with a Snyder high compression head is $5,000 and is worth trying to win. The missing parts should be easily obtained if you are the lucky winner!
Thanks,
Fred
Fred Carlton
Life Member AACA
Old 04-26-2013, 05:23 PM   #6
Gary WA
Gary WA's Avatar
New crank gear
Rebuilt oil pump
New valve springs
Motor balanced
New oil pan bolts
New front pulley
New head gasket
New clutch disc
New pressure plate
New pilot bearing
Modern front seal
Make checks payable to "50th Model A Ford Texas Tour" and mail to:
How's shipping going to work winner responsible??
www.whidbeymodelaclub.com
Old 04-26-2013, 05:51 PM   #7
700rpm
700rpm's Avatar
If you won a $5000 engine with a $5 ticket, you think you could come up with $800 to ship it to Washington?
Ray Horton, Portland, OR
Old 04-26-2013, 06:05 PM   #8
Gary WA
Gary WA's Avatar
possibly!!!
Old 04-26-2013, 06:12 PM   #9
BrianM
BrianM's Avatar
Please excuse the ignorance, but does "one piece bearings" mean babbit?
Update: Sorry, I didn't pay attention to the title, but how are inserts one-piece?
BrianM is offline   Reply With Quote
Old 04-26-2013, 09:01 PM   #10
lookin-backtexas
To answer your question, if you buy a ticket and win, the contest rules state "winner need not be present to win but must claim prize on or before July 1, 2013." That means it's your engine and on or before July 1 you have to pick it up or have it shipped to you.
I will personally be at the awards banquet that evening and if you are from out of state and need some time to arrange shipping or storage until you can drive here to pick it up, I will store it in my barn for a reasonable amount of time (couple of months if necessary).
Don't know the cost of shipping but if you are lucky enough to win a $5,000 engine, I would think the additional cost for shipping or gas to come pick it up would be worth it - you've always wanted to visit Texas anyway, right?
Fred
Fred Carlton
Life Member AACA
Old 04-26-2013, 09:07 PM   #11
lookin-backtexas
Brian:
No, the engine has insert bearings instead of babbitt. I just got off the phone with the engine builder and what he meant by stating "one piece bearings" refers to the fact that most engine rebuilders who do inserted engines have historically used what he calls "old technology" meaning they use MG bearings that are not wide enough to fill the gap in the block and used two separate bearings on each half. He uses a single bearing on each half (obviously you can't have a one piece bearing that wraps around the crank). He pointed out another advantage in doing so in that the old technology resulted in a gap between the two bearings at the rear main; his single bearing fills the entire space resulting in no gap.
Hope this answered your question.
Thanks,
Fred
Fred Carlton
Life Member AACA
Old 04-26-2013, 10:41 PM   #12
Gary WA
Gary WA's Avatar
Fred
thank you!!!
Old 04-26-2013, 11:50 PM   #13
CarlG
CarlG's Avatar
Don't worry about it Gary, they are going to pull my ticket anyway.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-27-2013, 01:22 AM   #14
bonesy
bonesy's Avatar
Do you all take PayPal. I'd be in for five.
Thanks,
Scott
bonesy is offline   Reply With Quote
Old 04-27-2013, 05:38 AM   #15
dr.j
Open to your neighbours up north? I'd drive down for the tour and pick it up
Dave A Jamieson
Portland, ON
Canada
1928 Tudor
dr.j is offline   Reply With Quote
Old 04-27-2013, 06:35 AM   #16
montanafordman
montanafordman's Avatar
Well, since I need an engine, I might just have to buy a ticket!
montanafordman is offline   Reply With Quote
Old 04-27-2013, 06:42 AM   #17
QGolden
QGolden's Avatar
I'll buy a couple of tickets. When I win it, I will have a great excuse for a Road Trip. :-)
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 04-27-2013, 06:55 AM   #18
lookin-backtexas
Carl - now that would make a fun road trip . . . Alaska to Texas! Hope you plan to drive your Model A. A few years ago, a local guy drove his Model T from Austin, Texas to Alaska roundtrip - now that's a real road trip at 30 mph! Took him a couple of months for the roundtrip!
Fred
Fred Carlton
Life Member AACA
Old 04-27-2013, 06:56 AM   #19
lookin-backtexas
Thanks,
Scott
Hi Scott - unfortunately no Pay Pal but we'll take cash, check or money order!
Thanks,
Fred
Fred Carlton
Life Member AACA
Old 04-27-2013, 07:01 AM   #20
lookin-backtexas
Hi Dave, sure Canadians are more than welcome - if you are serious about wanting to drive down for the tour, here's how to register to attend:
http://www.texasmafc.com/2013/index.html
Just click on the link for "Tour registration form" and fill it out. We'll see you in June.
I was Tour Chairman the last two times our club hosted the Texas Tour and we have had as many as 550 Model A'ers show up to attend and some have driven their Model A from as far away as California and Georgia. It's always a fun event and this is a significant tour because it's the 50th Anniversary of our statewide tour.
Thanks,
Fred
Fred Carlton
Life Member AACA
