Old 08-09-2010, 09:28 PM   #1
mrtexas
mrtexas's Avatar
Default MaxJax 2 post car lift
I'm tired of jacking up my Model As and other cars so I'm excited to pick up my MaxJax tomorrow from Yellow Freight. Hey, Jay Leno has one! I have 9 foot ceilings in my garage and I can't pick up my Model A Ford or the 63 Corvette verte any higher than 48inches which is how high this lift goes. Projects planned are throttle body FI for the 63 corvette, put 29 roadster back together after painting, install new engine in 28 RPU.
I had to buy 7/8 inch concrete bits, the impact bit and rebar cutter. I already have the 5/8 inch bits required from my add 40 feet to the garage and build a 20x20 portacachre project of last year.
One advantage to this lift is that the posts can be unbolted and stored away. The lift mechanism is also movable. I intend to install it in my main 2 car garage area on the right hand side and unbolt the left side post after use to make door opening easier.
http://www.maxjaxusa.com/
mrtexas is offline   Reply With Quote
